Questions about putting the 96-00 sohc greddy kit on a d16z6
I've quit using this account
i have a few questions,
has anyone done it?
i have no doubt it will fit, they (y8 and z6) are pretty much the same motor.
how about injectors? the ones that come with the new greddy kit are made for odb2 cars?
will they (the injectors) work on my z6? or will i have to get different clips?
also wiriing up the manage? i know with the blue box all you had to do was soder it to different wires? can this be done with the emanage?
any help you can give would be great thanks,
kelly
has anyone done it?
kelly
Re: Questions about putting the 96-00 sohc greddy kit on a d16z6 (llewsirc)
the manifold will fit for sure, the piping will be a little off tho. and mounting brackets will be different. The injectors will work as long as your car uses saturated injectors. The kit should come with new clips that you use for the new injectors. Im not sure, but I think the e-manage install is similar to the blue box.
thank you for your help,
i was told if you get the clips from a odb2 car and splice them in they will work, can anyone confrim this?
the emanage will wire up (from what i have been told too), all you have to do is find the right wires (they will be in different spots on the ecu... same wire drifferent spot)
why will the piping be alittle off? are the IM's that different? what mounting bracket are you talkin about?
thanks again
kelly
thanks again
kelly
Re: (llewsirc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by llewsirc »</TD></TR><TR><TD CLASS="quote">
kelly</TD></TR></TABLE>
Well i kinda assumed you had a different year civic than 96-00 cause they don't dome with z6's. So the main reason the piping will be off is because the car is not a 96-00. I used the 92-95 sohc greddy kit on my 99 civic and the piping was the only thing that was kinda off. Just had to modify it a little.
Re: (llewsirc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by llewsirc »</TD></TR><TR><TD CLASS="quote">wow, no one will help a trial member huh?</TD></TR></TABLE>
What else do you want to know? yes the injectors will work, greddy kit will come with new clips, yes the emanage is wired similar to the blue box.
Re: (llewsirc)
The SOHC kit comes with injectors now? when did they start that. The DOHC ones come with 310cc but i'm pretty sure the SOHC doesn't come with any, unless they just changed it in the past few months. The wiring on the blue box/ e-manage will be diff also. But they have updated wiring on here though.
