Turbo Choice
Old Mar 2, 2007 | 09:06 AM
lsvtec225's Avatar
Default Turbo Choice
Im new to the turbo thing, so bare with me.
I usually build NA auto X cars.
Well i have a 2000 Civic Si, it has a B17 with eagle rods, Je pistons, Block guard and built skunk 2 head.
My goal is to make 350 whp. This car is track only and will be running on pump fuel with some octane booster. I want it to be able to spool fast and still be able to put up some good numbers!!!
Any suggestions on turbo kits and what psi to run would be nice!!!
thanks!!!
Old Mar 2, 2007 | 10:44 AM
urbansi's Avatar
Default Re: Turbo Choice (lsvtec225)
full race stage one kit with the gt2871R with the .81 A/R. quick spool and should make around 350 with out a problem.
Or you could put something together yourself for less.
Old Mar 2, 2007 | 12:09 PM
Schister66's Avatar
Man U FTW
it all depends on your budget. You can buy the parts of a turbo setup from people in the Marketplace and then put whatever turbo you want with it. The GT28RS is a good turbo. It will make enough power for you and will have nice response if you plan to AutoX/road race/daily drive.
There are less expensive options out there as well....like the GT3251E
Old Mar 2, 2007 | 03:17 PM
THEDirtyDseriesWOOT's Avatar
gt28 FTW full boost by 3k and all the way till redline perfect auto x turbo
Old Mar 2, 2007 | 08:45 PM
lsvtec225's Avatar
Default Re: (THEDirtyDseriesWOOT)
thanks for the replys guys!!!
u can see why im so confused with so many options!!
But since im not in a huge rush i think im goin to buy most stuff used and just buy the turbo new after i've pieced it all together!!!
thanks
Old Mar 2, 2007 | 08:48 PM
lsvtec225's Avatar
Default Re: (lsvtec225)
How about a Greddy TD05H-18g
Just wondering becasue this is the most popular turbo kits for the local import performance shop!!!
You know u got to support the local shops!!!
Old Mar 2, 2007 | 09:52 PM
its gonna fall on its face top end.. thats why its Cheap
Old Mar 3, 2007 | 07:04 AM
Garage 808 Hatch's Avatar
i wouldnt get a .81 ar exhaust for a auto-x car. id look for a .63
Old Mar 3, 2007 | 11:44 AM
Killa's Avatar
Default Re: (Garage 808 Hatch)
you can go with a GT28 type turbo such as a GT28R, GT28RS or GT2871R. These are all dual ball bearing and use T25 flanges, options are .64 and .86 a/r's. You'll be better suited with the .64, as far as power, the 2871R will make the most but has just a bit more lag than the 28RS even thought they use the same turbine wheel.
The GT2871R can also be had with a T3 flange, in that case dont go over a .63 a/r.
hope this helps
Paul
Old Mar 3, 2007 | 05:32 PM
lsvtec225's Avatar
Default Re: (Killa)
wow thanks for the HELP!!!!
well ive narrowed it down... i know im getting a gt28 with .63
I dont really know too much about turbos so....is .63 the trim
if not what trim should i get
also what is the difference in gt28r and gt28rs
and what will these run me!!!
thanks alot
Old Mar 3, 2007 | 06:59 PM
Schister66's Avatar
Man U FTW
for the price, the GT3251E is hard to beat...PM TheShodan and he'll get you more info about it...
civic-r11
Feb 26, 2009 06:48 AM
boostnhatch
Nov 29, 2007 08:45 AM
broketuner-Sol_Si
Jan 26, 2006 05:08 PM
Turbo Powa
Jun 7, 2002 06:21 PM
