Need advice 8500 rpm rev
Old 10-07-2013, 05:45 AM
BoostModeCivic's Avatar
Default Need advice 8500 rpm rev
I Have A Turbo D Series That I Currently Rev To 7500 Rpm . The Head Is All Stock , I Want To Rev It To 8500 Rpm . As Far As I Know All I Will Need Is Springs And Retainers, Any Suggestions On What Spring & Retainers I Should Get ? Supertech? This Is A Daily Driver , But I Do Drag Strip It A Bit Just For Fun , Will Stock Cam Be Ok?
Old 10-07-2013, 06:29 AM
Turbo-LS's Avatar
Default Re: Need advice 8500 rpm rev
You need springs retainers keepers and supporting Camshafts. You can't just rev that high for the hell of it. It's prob not making power much past 7000 as it sits. Is the block stock too? If the bottom end is stock I would go any higher than you are right now
Old 10-07-2013, 10:01 AM
Block Is Built, Pistons, Rods , Block guard ,Bearings
Old 10-07-2013, 10:04 AM
Turbo-LS's Avatar
Ok then valve train and camshaft upgrades will
Be the nessesity here. What turbocharger are you running? What intake manifold? Turbo manifold?
GC106XT
02-23-2014 06:48 AM
TurboB16A300Hpteg
01-05-2008 07:18 PM
champLSinteg
08-26-2006 07:36 AM
175Shot4Door
08-22-2006 07:44 PM
thedirty-Dseries
04-18-2006 07:16 PM
Quick Reply: Need advice 8500 rpm rev
