Necessary Turbo Upgrades. (engine)
Old 09-29-2002, 06:14 PM
RedHatch's Avatar
Default Necessary Turbo Upgrades. (engine)
I currently have the engine i want to turbo apart.
And i was wondering what is necessary for the internals. I want to spend as little as possible. Should i invest in pistons\rods or into valves\springs retainers. Or should i just port and polish...
I want to get the most amount of boost with these least amount of internal upgrading....
Any help thanx.
Old 09-29-2002, 06:48 PM
ekb18c's Avatar
Default Re: Necessary Turbo Upgrades. (RedHatch)
Definitely do pistons and rods!
Springs and retainers you can keep stock since you wont be reving too high to achieve max hp.
BTW: Turbo and cheap don't go together very well.
Old 09-29-2002, 06:53 PM
pelotudo's Avatar
I want to spend as little as possible. I want to get the most amount of boost with these least amount of internal upgrading....
Out, get out. Back to N/A 4 u . If you are going to boost, don't go cheap on it. Forced Induction is just an expensive way to blow your engine if you don't do it right. If you want "the most amout of boost with these least amount of internal upgrading...."; get a Zex kit... Technically it's forced induction
Rods/Pistons should hold you for a while. A mild P&P will flow a lot better. Grab those 2, and start working on spending $$$ for fuel management, that's the kicker.
jB
PianIan
11-07-2013 10:45 AM
ek9tl
13
04-14-2007 09:49 PM
b16greenmachine
12-25-2005 06:40 PM
tjohnson329
12-16-2004 09:06 PM
AmericanNightmare
05-20-2003 06:33 PM
Quick Reply: Necessary Turbo Upgrades. (engine)
