My new civic turbo need help
I just installed a t3 turbo on my d16y7 minime. I get like no boost till 6700 in first and 6000 in second, and its like nothing. The max I was able to put out was .48 kg or boost according to the afc. It does have a frontmount. I dont see a leaks, except for the downpipe. It a big leak. Im using chrysler 2.2l t3. Would that cause it.
Re: My new civic turbo need help (Eaglekper0046)
is the wastegate closed? Make sure all your couplers are tight on your intercooler piping, and your blow off valve isn't leaking.
Re: My new civic turbo need help (coneheadsracing)
Ill look at it, anyother ideas. The downpipe leaking would have anything to do with it. I know the turbo runs off heat and exhaust.
Re: (nonvtecD)
same engine as you last year, .48/.60 i know it has to do with trim too. Nonetheless, i could build 15 psi, by 4k no probs at all.... so yes you have a leak, either in the charge pipes, or with your wastegate.
Re: (nonvtecD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD »</TD></TR><TR><TD CLASS="quote">do you have engine management? </TD></TR></TABLE> 315cc injecters apex afc, msd btm
Re: (nonvtecD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD »</TD></TR><TR><TD CLASS="quote">do you have engine management? </TD></TR></TABLE> Really whats that have to do with me not getting boost
Re: (Eaglekper0046)
My vote is boost leak. And it's sizable.
Oh.. One more thing.. If you have a Tial WG... Do you have your fire ring installed? When I first installed my turbo, I forgot it... And wasn't able to make any significant boost.
Modified by scartail at 7:06 PM 5/16/2006
integraautox
05-24-2003 03:33 PM
89civic1.8T
05-18-2002 11:23 PM
