My First B16a Boost Project
Old Nov 6, 2007 | 10:44 AM
  #26
gendai_8's Avatar
Default Re: My First B16a Boost Project (b16a4)
What kind of turbo inlet pipe is that (the one for the air filter)? Where did you get it?
Thanks
Old Nov 7, 2007 | 05:00 AM
  #27
b16a4's Avatar
Default Re: (TheShodan)
I Made 213Whp at 7psi.
Edit
7psi spring
6psi on boost guage
Modified by b16a4 at 10:25 AM 12/2/2007
Old Nov 7, 2007 | 06:15 AM
  #28
TheShodan's Avatar
Moderator
Default Re: (b16a4)
you can go a little higher, no more than about 10psi though.. for the surfer, its really out of its good range at 7psi. but good job, nonetheless.
Old Nov 7, 2007 | 08:36 AM
  #29
TIGboy's Avatar
you'll fall out of boost simply because the turbo will not be spinning enough to continue to pick up quickly after the throttle opens again from shifting, its just a big turbo and that b16 with that turbo at 5psi is almost a waste. but 7psi thats a start, I would keep going. good luck!
Old Nov 13, 2007 | 07:01 AM
  #30
mike02cky's Avatar
Default Re: (TIGboy)
how bout on a b16 with forged rods and pistons and stock head runnin the silver surfer? what would be an efficient and safe boost level? 15lbs of boost?
Would a mildly built b16 do good running about 15lbs on the silver surfer? any ideas on power output? and how safe is that with a good tune? with 450 injectors?
the silver surfer is the gt3255 right? and whats the max potential of that turbo?
Old Nov 13, 2007 | 07:17 AM
  #31
HarfordCTR's Avatar
Default Re: (mike02cky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike02cky &raquo;</TD></TR><TR><TD CLASS="quote">how bout on a b16 with forged rods and pistons and stock head runnin the silver surfer? what would be an efficient and safe boost level? 15lbs of boost?
the silver surfer is the gt3255 right? and whats the max potential of that turbo?</TD></TR></TABLE>Those 450 injectors will be no good for that.
Old Nov 13, 2007 | 08:08 AM
  #32
bigbadboy's Avatar
if you can drive your car you shouldn't be falling out of boost anyway. just keep your foot to the floor and you'll never have to worry abt respool or falling out of rpms
ekturbo13
Feb 20, 2011 08:39 PM
sleepercivic88
Apr 7, 2009 03:45 PM
EGLUVN
Sep 11, 2007 06:43 PM
TurboEM1
Apr 30, 2006 04:16 AM
boostdummy
Oct 28, 2005 08:37 PM
