my car is smoking
Old Mar 28, 2003 | 11:45 AM
DAinfamousR's Avatar
Default my car is smoking
i recently did a compression test wet and dry... 150 across.. what do you guys think... i thought i was the turbo cuz i did find oil in the charge pipes.. so i sent the turbo to get rebuilt and clean out all the pipes.. but its still smoking.. anyone have some advise
Old Mar 28, 2003 | 11:49 AM
93LSivic's Avatar
Default Re: my car is smoking (specRtunedgSr)
Valve seals or guides. Fuel washing cylinders. Bad PCV.
What color is the smoke?
Old Mar 28, 2003 | 11:55 AM
94TealGSR's Avatar
Are you running a stock GSR block? Compression should be well above 150 if you are..
Old Mar 28, 2003 | 12:19 PM
BLAP BLAP!!!
Guest
Posts: n/a
Default Re: my car is smoking (94TealGSR)
i know this has nothing to do with your prob.. butt where in el paso u from?? i lived there for a long time
Old Mar 28, 2003 | 12:21 PM
Flamenco-T's Avatar
Default Re: my car is smoking (turbocr-x)
you're right !!, it has nothing to do with it...yum yum LOL
stan
Old Mar 28, 2003 | 12:23 PM
Flamenco-T's Avatar
Adrian,
1. your compression should be above 180ish on dry...
2. have someone follow you when you're driving, if smoke comes out at full throttle, it's usually your rings
if smokes comes out while deccelerating, it's usually valve guide seals
3. is it a bluish colored smoke ?
4. get leakdown tested, see if it's rings or valves
stan
Old Mar 28, 2003 | 06:20 PM
Default Re: my car is smoking (93LSivic)
people say that its kinda of blackish some say blueish.. i check the pcv and also cleaned it out.. it looks fine..the block is done lowered the compression to 8:1 they said 150 was fine..
turbo crx i live in east el paso
the car usually smokes when i take off in first or when i coming to a stop.. i took it to the track and still hit constant times.. my mph went up 2mph..
Old Mar 28, 2003 | 06:54 PM
turbochic's Avatar
Yep it sounds like your rings have seen better days. What is probably happening is that small amounts of oil are makeing there way thru the ring seals, its called oil blow by (dont quote me on that) but anyhow yes it would be a good time to replace those with a good set. The smoke you see is from the oil being burned up by the intense heat of your exhaust.
Old Mar 28, 2003 | 08:44 PM
Default Re: my car is smoking (fmaxturbochic)
thanks to all of u.. i guess the best thing to do now is tear the block and rebuild it.. and once again thanks
Old Mar 29, 2003 | 12:51 AM
blufke's Avatar
nice to see someone local. do you go to the sunday night drags at the airport? i am from cruces.
Old Mar 29, 2003 | 01:04 PM
Default Re: my car is smoking (blufke)
i really dont go to the airport.. its a waste of time.. my opinion.. were usually at the illegals or thunder alley which i think already closed...
Old Apr 27, 2003 | 12:33 AM
GOLDBERG's Avatar
did u ever determine what it was???
and how hard/expensive is a valve seal change??and what could/would cause them to leak?
Old Apr 27, 2003 | 12:57 AM
stockegsix's Avatar
Default Re: my car is smoking (GOLDBERG)
im getting smoke too w/ my turbo, yeah theres no smoke when im on boost or at idle, i usually see a puff when im slowly accelerating.
how hard is it to change valve seals and piston rings? where to get and how much will they cost.
TTT
92 cx
boosted b16a
jdmcivic2fast
Aug 6, 2012 08:38 PM
Chuji
Aug 3, 2012 04:33 AM
HondaEF8R
Nov 25, 2007 06:58 PM
wshondamanturbo
Oct 10, 2005 02:13 PM
Pfieff
Mar 8, 2004 07:19 PM
