Smoking problem with leakdown and compression #'s
Old Aug 1, 2012 | 03:16 PM
Chuji's Avatar
Default Smoking problem with leakdown and compression #'s
I am getting white/blueish smoke under WOT from 5k rpm to redline. It's not too bad but enough to notice a haze out the rearview after doing a hard pull. Compression test was 230-240 on all cylinders. I did a leakdown test and I'm getting the following readings:
Cyl 1: 6-7%
Cyl 2: 2%
Cyl 3 :2%
Cyl 4: 6-7%
Are the leakdown numbers bad enough to cause my smoking issue? I am thinking its a bad turbo seal because I have been running this turbo hard for 3+ years and bought it used. There is no telling how many miles are on it. What do you guys think?
Running 10psi on a stock jdm gsr tuned on chrome.
Old Aug 2, 2012 | 09:11 PM
Chuji's Avatar
Default Re: Smoking problem with leakdown and compression #'s
Anyone?
Old Aug 3, 2012 | 04:33 AM
VTC_CiViC's Avatar
Those leakdown numbers aren't bad for a motor with a few miles, perhaps the turbo is ingesting a little oil at higher pressure loads? PCV system plumbed into the intake or seperated? Have you looked at the plugs for signs of oil consumption?
95greenlude
Nov 3, 2007 04:21 PM
climb_on
Jul 29, 2007 03:40 PM
JDMtype Eg6
Jul 14, 2007 02:31 AM
model x
Oct 26, 2005 02:01 AM
Pfieff
Mar 8, 2004 07:19 PM
