Is my BOV Dead???
Old 06-21-2001, 05:48 AM
DragII's Avatar
Default Is my BOV Dead???
My bov (hks SS??) is not actuating unless I let off the pedal under boost. It used to go off all the time, at least a little. also...it is the kind w/ two bolts that hold it to the flange, and it's also adjusted by those two bolts however..it has lost its adjustability. as soon as vaccum hits it...the diaphram sucks the spring all the way in, and it looses tension on the flange and just hangs there...the only way to correct it is by tightening it all the way down...WTF!!!
Old 06-21-2001, 05:53 AM
Ubermensch's Avatar
Default Re: Is my BOV Dead??? (DragIIcivic)
Huh? I thought the point of the BOV was to only release when you let off the pedal under boost. If it were going off all the time whats the point? You're not confusing the BOV with the wastegate are you? Or am I just totally missing what you're saying?
Old 06-21-2001, 06:04 AM
DragII's Avatar
Default Re: Is my BOV Dead??? (Ubermensch)
c'mon man...have a little more faith in me...I've been doing this for a while.
the bov used to actuate every time I let off the pedal, even if only a little...the more boost I was in the louder it would be...at this point...it is only actuating after letting off under full boost, and somewhat after partial boost.
[Modified by DragIIcivic, 10:04 AM 6/21/2001]
Old 06-21-2001, 07:36 AM
Ubermensch's Avatar
Ahh...makes more sense. Didn't mean to underestimate you but there are plenty of strange posts....sorry I don't have an answer for you.
Old 06-21-2001, 07:43 AM
DragII's Avatar
Understood
Anybody got an Idea before I go shelling out a couple hundered bucks for a new one???
Old 06-21-2001, 10:53 AM
Seraph0's Avatar
Well that is definately very strange man.
I'm not sure I follow the problem about it "hanging in there." Is it the old HKS sequential BOV? (not the new super one)? I thought they used a C-clip to hold them in too. Have you eliminated all other possibilites? Vacuum lines, etc, etc.... weird man.
Old 06-21-2001, 10:58 AM
DragII's Avatar
Default Re: Is my BOV Dead??? (MarkC)
It's the old style w/ out c-clip. Its bolted on using the actuator spring for tension...but when vac hits it the spring fully compresses leaving no tension on the bolts.
Old 06-21-2001, 12:58 PM
TurboIntegra's Avatar
Just a thought-- Have you checked to make sure all your pipes are still connected tightly? Because one time I had a small leak at one of the connections and the air would just go out through the hole when I let off the gas instead of going through the BOV.
Old 06-21-2001, 03:06 PM
DragII's Avatar
Default Re: Is my BOV Dead??? (TurboIntegra)
yup... checked that...would it be possible for the spring to loose it's tension? Thats kind whats going on here....when vac hits it...it just fully collapses.
sikid111
05-05-2011 06:15 PM
bboysake
08-03-2006 02:41 PM
BlackB18CTeg
10-04-2003 11:16 AM
integranator
07-22-2003 11:00 PM
Quick Reply: Is my BOV Dead???
