msd boost retard (HELP)
Old Oct 10, 2005 | 06:12 PM
rlwturbosi's Avatar
Default msd boost retard (HELP)
Just installed an msd boost retard unit on my 2000 civic si turbo. At WOT the car runs fine until 5k then it bogs really bad. After a few times hitting boost it bogs really bad and does not accelerate at all. I then pulled over and unplugged the battery i stayed out of boost it was fine until i got home. I could use any suggestions. Thanks
Old Oct 10, 2005 | 07:02 PM
Sprayteg's Avatar
Default Re: msd boost retard (rlwturbosi)
too much timming retard?
Old Oct 10, 2005 | 08:27 PM
rlwturbosi's Avatar
Default Re: msd boost retard (Sprayteg)
I did not retard the timing everything is set a zero.
Old Oct 10, 2005 | 08:30 PM
flip1199's Avatar
what plugs u running and at what gap? what's your fuel setup?
Old Oct 10, 2005 | 08:38 PM
rlwturbosi's Avatar
Default Re: msd boost retard (flip1199)
bosch platinum 2s, 450 dsms tuned with v-afc. Tune is great , it is just pulling timing and i don't know why.
Old Oct 10, 2005 | 09:28 PM
rlwturbosi's Avatar
Anything else it could Be?
flip1199's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rlwturbosi &raquo;</TD></TR><TR><TD CLASS="quote">bosch platinum 2s, .</TD></TR></TABLE>
change those to ngk bkre7e-11 or 3330 and start out at .033 gap and see how that works
Old Oct 11, 2005 | 03:54 AM
JSPECSIR's Avatar
make sure your msd piece does not have jumpers you have to cut for 4,6,8 cylinder. if it does make sure they are cut correctly. if not call msd.
Old Oct 11, 2005 | 05:58 AM
Finland's Avatar
I had a similar problem, except mine would stutter at anything above 7K with anything more than .5 degree retard per 1 Psig boost. I ended up having to just keep the dial at zero. Then I went Hondata and the rest is history.
haveaNOSday
Dec 3, 2006 10:43 AM
AJxr
Dec 14, 2005 08:20 PM
sPaRk'iT
Apr 26, 2004 05:46 PM
Tad
Dec 17, 2003 03:10 PM
JDM EX
Aug 5, 2002 09:50 PM
