boost timing master question
Old Dec 2, 2006 | 07:23 PM
haveaNOSday's Avatar
Default boost timing master question
I did a search and found no results... do you need to put a ignition amplifier in conjunction with the msd btm
Old Dec 3, 2006 | 10:43 AM
littlebluecrx's Avatar
Default Re: boost timing master question (haveaNOSday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haveaNOSday &raquo;</TD></TR><TR><TD CLASS="quote">I did a search and found no results... do you need to put a ignition amplifier in conjunction with the msd btm </TD></TR></TABLE> A btm is like a 6al with a boost retard option. So unless you are gonna run more cylinder pressure, than that ignition can fire, probaly not. I have run 6 al's on cars make 700 whp, and they never miss a beat. I just gap the plugs dont to .015 on high boost applications....
calvinPGMFI
May 3, 2004 05:31 AM
sPaRk'iT
Apr 26, 2004 05:46 PM
