MSD boost timing master, does it help??
Old Apr 25, 2004 | 01:15 AM
sPaRk'iT's Avatar
Default MSD boost timing master, does it help??
i have seen MSD timing master controller around and i did do a litttle reserach but couldnt find what i was looking for, what does it really do and do i really need it??
Old Apr 25, 2004 | 06:40 AM
wade's Avatar
Default Re: MSD boost timing master, does it help?? (sPaRk'iT)
you need some kinda of igniotion retarding control non the less get a standalone or something, no piggy back **** please )
when u boost, you need to retard your ig timing for several reasons, yes it decreases a few ponies but its make ur engine happy, liek .75 degree retard per pound of boost. helps pre-det, detonation, knock and that affiliatted things.
Old Apr 25, 2004 | 06:45 AM
USDM 4G VTEC's Avatar
like wade said
the MSD BTM retards ur ignition timming /per pdn of boost..
before ur engine sees boost it runs normally, once it boosts, this ignition will start retardign ur ignition to avoid detonation
Old Apr 25, 2004 | 08:28 PM
sPaRk'iT's Avatar
Default Re: (USDM 4G VTEC)
so do i control the retard myself or does it do itself?
Old Apr 25, 2004 | 10:23 PM
Smokinsax's Avatar
The Boot
its got a **** on it that you pre-set. 0-3 degrees on mine per pound of boost.
Old Apr 26, 2004 | 05:46 PM
turboteg2nv's Avatar
Default Re: (Smokinsax)
bit off topic here...but if you use a VAFC vs. an SAFC will it advance timing despite the use of a BTM?
Tad
Dec 17, 2003 03:10 PM
JDM EX
Aug 5, 2002 09:50 PM
