gsr cams in b16 head
Old Mar 7, 2005 | 09:27 AM
esp4life's Avatar
Default gsr cams in b16 head
i have some gsr cams/springs/valves and was wondering if there would be any significant difference if i put them in my b16. i have an ls block that i plan on doing lsvtec with and turbo in hopefully near future. i have jun cam gears that i plan on using, just wondering which cams to put them on.
Old Mar 7, 2005 | 01:21 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: gsr cams in b16 head (esp4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esp4life &raquo;</TD></TR><TR><TD CLASS="quote">i have some gsr cams/springs/valves and was wondering if there would be any significant difference if i put them in my b16. i have an ls block that i plan on doing lsvtec with and turbo in hopefully near future. i have jun cam gears that i plan on using, just wondering which cams to put them on.</TD></TR></TABLE>
The B16A1 cams are the weakest B series cams made. GSRs are slightly better than the A2s. It wouldn't hurt to run the GSRs, although I would recommend a set of CTR cams if you plan on keeping it OEM.
Modified by LSVTEC 91 Civic at 5:38 PM 3/7/2005
Old Mar 8, 2005 | 07:38 AM
esp4life's Avatar
Default Re: gsr cams in b16 head (LSVTEC 91 Civic)
how do you mean weakest?
Old Mar 8, 2005 | 07:51 AM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esp4life &raquo;</TD></TR><TR><TD CLASS="quote">how do you mean weakest? </TD></TR></TABLE>
Least amount of lift and duration compared to all other B series cams.
Old Mar 8, 2005 | 09:45 AM
esp4life's Avatar
should i make any other changes to the engine or ecu? will i need a gsr timing belt? i know there will be more to it than taking out the old cams and putting in the new ones ... what all will i have to do?
Old Mar 8, 2005 | 09:52 AM
mmuller's Avatar
Mad Scientist
mmm dohh... he means that they break easier..
Old Mar 8, 2005 | 12:14 PM
DavidT or VajT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esp4life &raquo;</TD></TR><TR><TD CLASS="quote">should i make any other changes to the engine or ecu? will i need a gsr timing belt? i know there will be more to it than taking out the old cams and putting in the new ones ... what all will i have to do?</TD></TR></TABLE>
It's a direct swap, you can use your B16 timing belt. Also that's all there is to it...just taking out the B16 cams and dropping in the GSR's
Old Mar 8, 2005 | 12:25 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">
Least amount of lift and duration compared to all other B series cams. </TD></TR></TABLE>
..mainly the cams out of auto 1st B16's are really really really amusing to look at
GSR cams are worthy upgrading to, they'll give you a little more torque over any generation of B16A cams. Of course Type-R cams are choice over any of the OE VTEC B-series cams.
longshot
Sep 26, 2008 09:32 AM
Tuahe556c
Apr 18, 2006 10:00 AM
GWInquisitor14
Sep 7, 2005 06:25 AM
91b16civic
May 13, 2003 04:26 AM
