missing link
Old Apr 25, 2005 | 08:48 PM
redlseg's Avatar
Default missing link
is it really needed for a turbo set up? and what is its purpose?
Old Apr 25, 2005 | 09:38 PM
redlseg's Avatar
Default Re: missing link (95eg6allmotor)
Old Apr 25, 2005 | 11:32 PM
illusive's Avatar
depends on what you want to run if your going to run hondata, uberdata, emanage or afc hack no. If your running a fmu or just running afc on stock injectors then yes you will need it. Missing link is to release pressure before the map sensor can see it. If your map sensor sees boost it will pop a code and your car will run like poo
Old Apr 26, 2005 | 07:16 AM
redlseg's Avatar
Default Re: missing link (illusive)
does the missing link bolt on the map sensor? or the tps sensor?
Old Apr 26, 2005 | 07:18 AM
Muckman's Avatar
Moderator in Chief
map sensor. its a valve that stops the map sensor from ever seeing boost. used on stock ecu's that freak out when they see positive manifold pressure and trigger a CEL.
Old Apr 26, 2005 | 07:20 AM
redlseg's Avatar
Default Re: missing link (Muckman)
alright cool thanx u guys
l2yanE
Oct 2, 2005 10:15 AM
dominate9
Nov 15, 2003 01:01 PM
Turbo EG6
Aug 19, 2001 05:04 PM
