mfactory catch can
Old May 29, 2010 | 01:01 AM
jtm509's Avatar
Default mfactory catch can
so i was trying to figure out a catch can setup and tried the line off the back of the block for a breather into a pop can, and it flows out about 1/4 to half a quart of oil every pull i do. I only have one breather plug in the back of the block and the valve cover breather going to a small mfactory catch can, any reason the block plug would be pushing out so much oil? i have the angle on it pretty high to where i thought it wouldn't be able to push any fluid out. any advice would be much appreciated. thanks
Old May 29, 2010 | 07:38 AM
Turbo-LS's Avatar
Default Re: mfactory catch can
this is tipical off useing the ports on the back of the block and require a real catch can and a drain back style system. Its best to run fittings off the front of the valve cover because its baffled and you wont get oil in the can or hardley any. i think i get 1/8 of a quart every 3000 miles
Old May 30, 2010 | 11:19 AM
jtm509's Avatar
so would it be best just to use the valve cover or setup a catch can that uses the valve cover and the plugs in the back of the block? And someone correct me if im wrong, but iv seen a lot of people say they wouldnt drain the stuff that collects in the catch can back into the motor but wouldnt that be exactly what the big catch cans are doing with the plugs in the back of the block?
blackeg
Apr 5, 2011 04:48 AM
lll_fusion_lll
May 20, 2010 05:55 AM
Listerofsmeg
Mar 30, 2010 06:07 AM
foxtrott501
Aug 4, 2008 07:50 AM
EK_vzla
Mar 18, 2008 05:34 PM
