problem with catch can
Old Aug 1, 2008 | 03:00 PM
foxtrott501's Avatar
Default problem with catch can
i have put one catch can in my setup , b20 vtec turbo, the 2 plug in the block have been drilled et tapes for put a fitting dans i have weld two other in the valve cover, myu catch can fulled of oil, i need to put something inside the fitting to retain oil in the block
please guy help me
thank
Old Aug 1, 2008 | 04:02 PM
b16bri's Avatar
Default Re: problem with catch can (foxtrott501)
WOW that was realy hard to understand. What type of catch can and dose it have a drain back feature ?
Old Aug 1, 2008 | 05:05 PM
90sedan's Avatar
Default Re: problem with catch can (b16bri)
I didn't really understand your post, but you may want to post some pictures if you aren't good with words.
Old Aug 1, 2008 | 06:09 PM
DaveF's Avatar
you need to move the fittings from the rear of the block....
put the fittings on the valve cover.
large diameter hoses only !!!! do not use small hoses, the air will carry more oil with small hose.
you can get a freeze plug for the black box(if you dont already have one) install a fitting into the freeze plug, then you have a drainback.
Old Aug 1, 2008 | 07:57 PM
SD_Lurker's Avatar
HT White Ops
Default Re: problem with catch can (DaveF)
I don't understand either. He says he has 2 fittings welded onto the block ports in the rear which would be drainback and then he said he has 2 on the valve cover. Now the only thing I can think of is that instead of the 2 block port fittings being on the bottom of the breather to allow for drainback they are located at the top of the can which obviously wouldn't drain.
Old Aug 2, 2008 | 04:51 AM
DaveF's Avatar
Default Re: problem with catch can (SD_Lurker)
oo good catch, i didnt see that the 1st time i read it !
about the ports on the back of the block.... those are major oil drain back galleys, foward acceleration= all oil in the head getting thrown against the backside, thus most all oil draining back these rear holes.
1 suggestion would be to remove whatever fittings are in there, plug the holes shut. maybe drain into the black box hole. z10 and B&R make plugs that can be tapped and a fitting threaded into.
Old Aug 4, 2008 | 07:50 AM
P.S.I Garage's Avatar
go buy the new issue of honda tuning aug. 08. they have a full article in there on how to install your catch can
B20vtec veteran
May 2, 2013 07:38 AM
blackeg
Apr 5, 2011 04:48 AM
jtm509
May 30, 2010 11:19 AM
sheepey
Oct 1, 2006 05:30 PM
912
Feb 12, 2006 05:27 PM
