crankcase vent- back of the block or valve cover??
Old Apr 3, 2011 | 05:03 PM
blackeg's Avatar
Default crankcase vent- back of the block or valve cover??
well ive been running the 2 fittings on the back of the block to my catchcan for the past few years. it occasionally pushes some oil into the catchcan. recently i came across an extra valvecover and had a friend weld 2 -10 bungs in it. i also drilled out the spotwelds on the baffle and removed it as it was right where the bungs went.
should i switch to the valvecover vents, even though the hose is a little bit smaller with the -10 than the hose i have currently to the back of my block??
Old Apr 3, 2011 | 05:27 PM
boostedBLUfg2's Avatar
Default Re: crankcase vent- back of the block or valve cover??
i would keep the vc with the bigger hoses
Old Apr 3, 2011 | 10:33 PM
vwbased's Avatar
have a nice day
Old Apr 3, 2011 | 10:59 PM
racebum's Avatar
baffles are a BIG benefit. learned this back in the day on an old 350. without them you spit a LOT more oil out
Old Apr 4, 2011 | 03:32 AM
EddieCRX's Avatar
I found having valve cover vents somehow equalise the pressure and stopped the oil from filling the catch can from the rear block breathers.
Old Apr 4, 2011 | 03:18 PM
blackeg's Avatar
Originally Posted by vwbased
You are going to need to reinstall the baffle in the valve cover. The added vent bungs need to be above the edge of the baffle.
i think i still have the baffle in my trashcan. i can take it back out and clean it off and tack it back in place. i took it out because i put the bungs on the back of the cover, not the front. it was kinda in the way of the drill when i put the holes in
Old Apr 5, 2011 | 04:48 AM
BigMike0147's Avatar
So you're saying if you put vents in block and in the VC it doesn't collect as much oil?? I'm asking because I plan on venting the back of the block with the Z10 kit. Thanks
slowassBubble
Jul 25, 2012 06:30 PM
jtm509
May 30, 2010 11:19 AM
lll_fusion_lll
May 20, 2010 05:55 AM
Cyphear
Dec 29, 2008 02:07 PM
EK_vzla
Mar 18, 2008 05:34 PM
