oil on catch can!!???
Old Mar 14, 2008 | 08:33 AM
EK_vzla's Avatar
Default oil on catch can!!???
its normal my catch can have a lot oil inside.... its T1 style catch can 2 block lines to catch and 2 on valve cover... maybe are the º on the hoses? i have cp piston on b16 block specs like cp`s need.....
fresh build dont have more than 200 miles
Old Mar 14, 2008 | 11:11 AM
sp00led's Avatar
Default Re: oil on catch can!!??? (EK_vzla)
Is it internally baffled like a real T1 can? Are you sure the hoses are able to drain properly since it is just gravity fed.
EK_vzla's Avatar
Old Mar 14, 2008 | 11:18 AM
EK_vzla's Avatar
Default Re: oil on catch can!!??? (sp00led)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sp00led &raquo;</TD></TR><TR><TD CLASS="quote">Is it internally baffled like a real T1 can? Are you sure the hoses are able to drain properly since it is just gravity fed.</TD></TR></TABLE>
yes its bafle, the problem i think its the gravity.... i going to change the valve cover hose whit the block hoses... i have the block hoses a litle down than valve cover...
on idle have 0 oil on the hoses (clear hoses) when you push the pedal nothing... i think its when make some boost they send the oil to the cacht
Old Mar 14, 2008 | 05:25 PM
dpetro1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK_vzla &raquo;</TD></TR><TR><TD CLASS="quote">
on idle have 0 oil on the hoses (clear hoses) when you push the pedal nothing... i think its when make some boost they send the oil to the cacht</TD></TR></TABLE>
well thats petty much a description of how blow by works. and im gonna bet that if you are using clear hose then your set-up is far from the T1 setup. i think we need to see some pics
Old Mar 17, 2008 | 07:34 AM
EK_vzla's Avatar
here its
Old Mar 17, 2008 | 03:01 PM
EK_vzla's Avatar
....need help!!!! they have 4 hoses... 2 on the block and 2 on the valve cover....
Old Mar 17, 2008 | 03:13 PM
Legion's Avatar
* B A N N E D *
Default Re: (EK_vzla)
It's kind of hard to break through the language barrier here... But it sounds like you're concerned about the can filling up. From the looks of it, there's no drain-back ability because the hoses from the block are on the side of the can, as opposed to on the bottom. I don't see how it has a chance to drain?
Old Mar 17, 2008 | 03:33 PM
Blown90hatcH's Avatar
Default Re: (Legion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legion &raquo;</TD></TR><TR><TD CLASS="quote">It's kind of hard to break through the language barrier here... But it sounds like you're concerned about the can filling up. From the looks of it, there's no drain-back ability because the hoses from the block are on the side of the can, as opposed to on the bottom. I don't see how it has a chance to drain?</TD></TR></TABLE>
Werd. Also, did you baffle the can? Did you baffle the rear of the VC too?
Old Mar 18, 2008 | 05:34 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
that is FAR from a T1 style catchcan.... and ya it looks like the fittings for the drain back aren't even near the bottom of the can to drain it back...
blackeg
Apr 5, 2011 04:48 AM
jtm509
May 30, 2010 11:19 AM
lll_fusion_lll
May 20, 2010 05:55 AM
laziebun
Dec 15, 2008 07:56 PM
Rod.
May 21, 2004 04:16 PM
