max overbore on b18c4?
Old May 3, 2009 | 08:23 AM
redsolturbo's Avatar
Default max overbore on b18c4?
lo guys.
quick question for you. what is the max safe overbore i can go on stock b18c4 sleeves?
i just picked up an engine for cheap (it dropped 2 valves and holed a piston) ripped it right down and the crank etc etc looks good (no scoring or spun bearings etc)
cylinder 4 that dropped the valve has marked the sleeve wall. i got some clay out and pushed it into the bore to see how far in it was dented/marked. looks to be 0.40mm deep.
manual states 81.5mm is the max limit, could i go as far out as 82mm if needed?
planning on running 9.5.1 forged pistons with eagle rods on a b16a head at around 8-10 psi (would be happy with 300 flywheel ponies and some nice torque)
cheers!
Old May 3, 2009 | 09:34 AM
kulo's Avatar
Default Re: max overbore on b18c4?
.5 for stock sleeves
Old May 3, 2009 | 09:58 AM
Schister66's Avatar
Man U FTW
For a boosted application, the largest you can go is 81.5mm on stock sleeves. You CAN go 82mm but with a turbo setup, you're liable to crack a cylinder wall. If you were building an NA setup, you could go 82mm...
Old May 3, 2009 | 10:03 AM
project dc2's Avatar
82mm is even pushing it for NA
Old May 4, 2009 | 02:06 AM
ok thanks.
really ought to measure the wall and see how far in the dents are. there are only one or two deep ones so lets hope a 0.5mm can remove them
failing that i guess i shall have to re-sleeve the engine
Old May 4, 2009 | 10:12 AM
hmmm i think i am not going to be ok on this.
for 0.5mm oversize that's 0.25mm from the total wall thickness right? (i reacon some of these dents are 0.30-0.40 deep into the wall)
worst case scenario, i either fit darton mid sleeves over here in the uk (if i can find someone to do it) or i have a b16a block sat here, but its crankless etc.
is it possible to fit the 87.5mm crank from my b18c4 (same crank as the type r) and run either a custom rod to give me my target 9.5.1 compression ratio? do eagle make custom length rods?
Old May 4, 2009 | 03:32 PM
jdmcoop's Avatar
You can do .020" over stock 81mm bore which would put you at 81.5mm
.25mm is .010"
Old May 4, 2009 | 07:03 PM
KillaSIPP's Avatar
Jg states 83mm on their max stock sleeve engines
Old May 5, 2009 | 03:38 AM
right i got some clay today and shoved it into the walls to get an imprint of the dents.
i think the deepest is around 0.20mm, so that 0.25mm hone/bore to take 81.5mm pistons should be ok :D (i have a digital tyre dept gauge with reads to 2 decimal points so i pulled it out 0.25mm and used that as a guide)
thanks for the advise. just need to build this up and hope this nasty b20 vtec engine i have holds together until its ready to go in :lol:
notoriousB
Mar 31, 2013 10:19 PM
2LiterTurboSeR
Jan 21, 2006 11:11 AM
j_wod2000
Dec 8, 2005 09:13 AM
MikeExt
Sep 18, 2003 03:58 AM
B18CHatch
Oct 30, 2001 11:11 AM
