max boost
Old Mar 6, 2004 | 02:35 PM
Turbo-Si's Avatar
Default max boost
whats the max amount of boost a b16a2 can hold with stock internals
Old Mar 6, 2004 | 02:37 PM
MaxSterling's Avatar
Default Re: max boost (Turbo-Si)
engine blows up due to whp not psi of boost
Old Mar 6, 2004 | 03:03 PM
Turbo-Si's Avatar
Default Re: max boost (MaxSterling)
well then is 10psi safe to run on a b16a2 with stock internalls and 63000 miles
Old Mar 6, 2004 | 05:07 PM
TABIAS's Avatar
I want to be MADE into Ice-T
bump
Old Mar 6, 2004 | 05:11 PM
b18cya94's Avatar
Default Re: max boost (preacherboy)
i know a guy running 12psi and a 20shot its still running for now~!
Old Mar 6, 2004 | 05:12 PM
vtecivic10's Avatar
yeah should be fine as long as you tune properly
Old Mar 6, 2004 | 06:55 PM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-Si &raquo;</TD></TR><TR><TD CLASS="quote">well then is 10psi safe to run on a b16a2 with stock internalls and 63000 miles</TD></TR></TABLE>
okay, read the above post AGAIN...he just answered you. its the WHP that is the determining factor, not PSI
mike
Old Mar 6, 2004 | 07:03 PM
Turbo-Si's Avatar
Default Re: max boost (MikeMAN)
well do the math. its about 10hp per pound and at 10lbs thats around 100 more hp give or take(correct me if im wrong) so this should be at an estimated 260hp so can this motor handle 260hp with stock internals?
Old Mar 6, 2004 | 07:24 PM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-Si &raquo;</TD></TR><TR><TD CLASS="quote">well do the math. its about 10hp per pound and at 10lbs thats around 100 more hp give or take(correct me if im wrong) so this should be at an estimated 260hp so can this motor handle 260hp with stock internals?</TD></TR></TABLE>
do WHAT math? you didn't say anything about WHAT turbo you would be running....10psi on a t25 is TOTALY different than 10psi on a SC61.
i am simply informing you that PSI isn't the limit, its WHP. But to answer your question, 260whp with stock internals is fine with good engine manangement.
mike
Old Mar 6, 2004 | 07:30 PM
b18cya94's Avatar
well the guy i am refering to is making 270whp
Old Mar 6, 2004 | 07:38 PM
MikeMAN's Avatar
Default Re: max boost (b18cya94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cya94 &raquo;</TD></TR><TR><TD CLASS="quote">well the guy i am refering to is making 270whp</TD></TR></TABLE>
yup, your post makes sense..im just trying to inform is all.
mike
Old Mar 6, 2004 | 07:51 PM
b18cya94's Avatar
hes on a 57trim t3t4
Old Mar 6, 2004 | 09:58 PM
turbosi03's Avatar
well, I'm putting down 268whp at 10psi on bone stock internals b16a2...
I just posted a dyno graph... here's the post:
https://honda-tech.com/zerothread?id=790735
pulls good
Old Mar 6, 2004 | 10:14 PM
TurboJesse
Guest
Posts: n/a
Default Re: max boost (turbosi03)
~300ish with stock compression...
hayabusa750
Feb 21, 2007 03:25 PM
vtak2nr
Jan 13, 2007 11:10 AM
89civicsiB18B
May 14, 2005 07:56 AM
ras
May 3, 2005 09:14 AM
markvqwerty
Aug 27, 2004 03:59 PM
