Can this be said about boost PSI
Old Jan 12, 2007 | 04:32 PM
vtak2nr's Avatar
Default Can this be said about boost PSI
It doesnt matter how much PSI you are running, it is the amount of HP that determines how much you can go without blowing **** up
Like lets say my car on stock internals can handle 200hp. Whether my turbo needs 5psi or 15psi its all good, as long as its only 200hp and no more, my engine will be safe. true or not?
Old Jan 12, 2007 | 04:43 PM
Oyvind Ryeng's Avatar
Default Re: Can this be said about boost PSI (vtak2nr)
I'd worry more about detonation than WHP and/or PSI. A detonating 200 WHP setup might or might not outlast a 600 WHP stock sleeve-build; as always - "it depends". In any case, the quality of the tuning of the engine management system has a profound effect on how long your build will last.
Old Jan 12, 2007 | 04:52 PM
numbnuts22715's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtak2nr &raquo;</TD></TR><TR><TD CLASS="quote">It doesnt matter how much PSI you are running, it is the amount of HP that determines how much you can go without blowing **** up
Like lets say my car on stock internals can handle 200hp. Whether my turbo needs 5psi or 15psi its all good, as long as its only 200hp and no more, my engine will be safe. true or not?</TD></TR></TABLE>
generally, yes.
like Oyvind said, there are added factors, like the tune.
If you have a safe tune, then it wouldn't matter how many psi it took to get to 200 whp.
Hope that clears it up.
Old Jan 12, 2007 | 06:05 PM
vtec.dc2's Avatar
what you said matters, but turbo effiency also plays a role. at some point turbo will go past efficiency range run hotter and lead to detonation. that normally won't happen cause just about every honda setup runs oversized turbo..
Old Jan 12, 2007 | 06:29 PM
HiProfile's Avatar
Default Re: Can this be said about boost PSI (vtec.dc2)
I have another question regarding boost PSI: why the hell do we get 2+ questions about it each week???
Theres more info than anyone could ever want in the archives, all it takes is 5 mins to find a thread with 20+ posts to learn about it.
Old Jan 13, 2007 | 07:12 AM
vtak2nr's Avatar
Default Re: Can this be said about boost PSI (HiProfile)
k so heres the situation
I have a d17.
The t3/t4 has shown to put out 160whp @ 5psi safely
I have a t3 super60 and someone said he got 160whp@8psi
My question is can I run my super60 @ 8psi safely or do I have to run it at 5psi
Old Jan 13, 2007 | 07:16 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtak2nr &raquo;</TD></TR><TR><TD CLASS="quote">k so heres the situation
I have a d17.
My question is can I run my super60 @ 8psi safely or do I have to run it at 5psi</TD></TR></TABLE>
what are you wasting your time for.... you can easily make 300WHP RELIABLE ALL DAY ON A BONE STOCK ENGINE @!@!@@@!@!!@@!!@@!!@@@@@@@@@!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!
Old Jan 13, 2007 | 10:13 AM
JDM_EH2's Avatar
Default Re: Can this be said about boost PSI (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">what are you wasting your time for.... you can easily make 300WHP RELIABLE ALL DAY ON A BONE STOCK ENGINE @!@!@@@!@!!@@!!@@!!@@@@@@@@@!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!</TD></TR></TABLE>
Not on a D-series...
Old Jan 13, 2007 | 10:15 AM
93supercoupe's Avatar
Default Re: Can this be said about boost PSI (JDM_EH2)
a d can make 300 but not easily as a B.
As long as u take into consideration of the limitations of the turbo, and other things, its safe to say u can say a certian HP is safe, aslong as everything else is up to snuff for the job.
Old Jan 13, 2007 | 11:10 AM
katoeh2o's Avatar
Default Re: Can this be said about boost PSI (93supercoupe)
Comon knowlage says that D-series is safe to about 200hp while B's do about 300. From what I have seen on the internet D series has weak rods.
Manny86
Sep 19, 2007 06:21 PM
broadheadjohn
Apr 15, 2007 11:48 AM
jdjustme
Mar 9, 2007 01:05 PM
93_delsol_si_gsr
26
Feb 10, 2007 12:10 PM
sikcrx80
Aug 4, 2003 09:23 AM
