map sensor for turbo???
Old Dec 24, 2005 | 09:45 AM
386kustoms's Avatar
Default map sensor for turbo???
hey guys i just made a turbo kit for my civic 97 dx question i did not put the map sensor in the piping should i and is there something i need for it like a missing link or chip the ecu??? this is the first turbo car i own that wasnt a turbo orig thanx
Old Dec 24, 2005 | 06:45 PM
jared99's Avatar
Default Re: map sensor for turbo??? (386kustoms)
yeah, you're gonna have to have one of those. On my 99 Integra just running an fmu, no chip, if the map sensor bypass isn't hooked up and you go into boost the ecu shuts the car into limp mode until i reset it. right now i'm running this thing called check valves that you make from vacuum line and aquarium valves. not professional and not really recommended but works temporarily and is like $10. basically just bleeds off boost so the map sensor never sees it. and you probably already know this, but it's not really in the "piping", it just sits between the map sensor and the top of the throttle body (on the integra anyway). if you want i can post a pic of where it goes or how to temporarily rig the check valve thing.
Old Dec 25, 2005 | 05:03 AM
386kustoms's Avatar
ok im thinking of the wrong sensor then, what is the sensor that goes in the intake tube right befor the throtle body???
Old Dec 25, 2005 | 05:35 AM
Adriano's Avatar
You are talking about the Air Inlet Temp (AIT sensor). Some people put in the Intake tube before the turbo, some people put it in the charge pipe, and on most 0bd1 engines they are placed on the intake manifold.
Adriano
Old Dec 25, 2005 | 05:45 AM
B16Civic93's Avatar
correct me if i'm wrong but isnt' it the intake air temperature sensor?
you are going to need that,
However you are going to need to do something to keep the map sensor from seeing boost, you can either buy a missing link or do the check valves like mentioned above. that is only if you are running an fmu, other programs like uberdata, hondata, crome etc... will allow the ecu to read boost with the stock map sensor up to something like 11.7psi
hope it helps
shaggyeg6si
May 15, 2008 07:48 AM
beaterman
Dec 26, 2006 06:08 PM
mjg10884
Feb 8, 2005 06:08 PM
