MAP sensor question
Old Jul 4, 2006 | 03:31 PM
zenon8890's Avatar
Default MAP sensor question
i have a d16a6 manifold on a d15b vtec, i'm going turbo in a week. just wondering cuz the stupid guys at the workshop said that the turbo setup wont work (what the hell), i'm going on a stock engine for my setup, whats the size od the map sensor my stock manifold has?!
and whats the safest PSI should i run on the d15b vtec
Old Jul 4, 2006 | 03:35 PM
USDM 4G VTEC's Avatar
by ur post i take u have a 88-91 ED chassis
the map sensor is on the firewall and its a 1.7 BAR
wich means it will work up to 11 psi
the D16A6 manifold doesnt have a MAP sensor location on it
Old Jul 4, 2006 | 03:40 PM
zenon8890's Avatar
Default Re: (USDM 4G VTEC)
yes i have 88 crx, i'm using some kind of a gerret turbo (dont know exactly wich one) but its a big one, i'm using turbo_edit and downloaded a ready rom from thier website, i dont know how much HPs i can get with that setup, thanks man, any tips for going 200hp on a stock engine?!
Old Jul 4, 2006 | 03:46 PM
do not run more than 7 psi
thats the most i will run on any stock (H) motor
Old Jul 5, 2006 | 05:04 AM
zenon8890's Avatar
7 psi=???? BAR?!!!
Old Jul 5, 2006 | 05:42 AM
Default Re: (zenon8890)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zenon8890 &raquo;</TD></TR><TR><TD CLASS="quote">7 psi=???? BAR?!!!</TD></TR></TABLE>
http://www.convert-me.com/en/convert/pressure
Old Jul 5, 2006 | 09:32 AM
spooncivic1's Avatar
you need to do some moreresearching before you go any further with your project
i mean, you dont even know what kind of turbo you have
Old Jul 7, 2006 | 04:04 AM
zenon8890's Avatar
the turbo is garret t28 out of an 1999 eclipse, front mount intercooler and custom piping. on 7 psi how much HPs i could get?!
Old Jul 7, 2006 | 08:27 AM
jared99's Avatar
Hmm...for some reason I was thinking the the Eclipse used a mitsubishi turbo on the 4g63 motors not a garrett. Unless it was installed later on the non-turbo motor.
Old Jul 8, 2006 | 07:55 AM
delsolsi94's Avatar
the 1999 eclipse used a t25, not a t28. You need to do some research because by the way your talking you have no idea what your doing, and when you go blind into a boosted set up, even if your not doing the install, all it does is lead to blown up motors
Old Jul 8, 2006 | 08:28 AM
jared99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zenon8890 &raquo;</TD></TR><TR><TD CLASS="quote"> i'm using some kind of a gerret turbo (dont know exactly wich one) but its a big one </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsolsi94 &raquo;</TD></TR><TR><TD CLASS="quote">the 1999 eclipse used a t25</TD></TR></TABLE>
Hmm..NOT big. On my friend's 99 GS-T it seemed like it would pull through the midrange but lacked high-end power.
Old Jul 8, 2006 | 09:02 AM
zenon8890's Avatar
hi, i just changed my turbo to a subaru impreza 98 turbo, and i have a mitsubishi frontmount intercooler came out evolution 3, how can i make my map sensor reads boost?!
Old Jul 8, 2006 | 09:46 AM
jared99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zenon8890 &raquo;</TD></TR><TR><TD CLASS="quote"> how can i make my map sensor reads boost?!</TD></TR></TABLE>
Why do you want it to read boost? Unless you're on a chipped ECU you're gonna get a cel and be shut down into limp mode.
If you meant how do you PREVENT it from reading boost, you can either buy a Missing Link or run a check valves setup.
Old Jul 8, 2006 | 12:13 PM
zenon8890's Avatar
Default Re: (jared99)
i'll chip my ecu with turbo_edit, i'm just checking everything before i have problems.
TooSmooth
Jan 24, 2011 06:19 AM
TheOdd001
May 21, 2008 05:39 PM
A BOOSTED CRX
Mar 28, 2008 04:25 PM
MugenFlaredCRX
Jan 11, 2005 08:54 PM
phiberoptik
May 6, 2003 09:43 PM
