Stock map sensor?
Old Jan 11, 2005 | 08:27 PM
MugenFlaredCRX's Avatar
Default Stock map sensor?
I read somewhere that the stock honda map sensor reads up to 11 psi. I'm not sure if its true. does anyone know anything about this?
Old Jan 11, 2005 | 08:31 PM
TeStUdO's Avatar
Default Re: Stock map sensor? (MugenFlaredCRX)
Here is a good thread for you to read
https://honda-tech.com/zerothread?id=1095919
It should answer your question and any more you might have about the map sensor
Old Jan 11, 2005 | 08:54 PM
Dunc's Avatar
BCICAN
Default Re: Stock map sensor? (TeStUdO)
Yes that is true. If you go over 11psi on a stock map sensor it "resets." In other words, you will run like 12psi, but the ECU reads zero. This isn't exactly what it is, but basically when it goes back to Zero psi there is zero fuel--->Boom.
JayDMJ
Engine Management and Tuning
Sep 9, 2017 12:24 PM
hatchBK4life
Feb 3, 2010 12:08 PM
daflagger
Nov 4, 2007 08:31 PM
fast[R]
Jul 18, 2002 03:00 PM
DIRep972
Mar 11, 2002 07:01 PM
