map sensor
Old Oct 9, 2006 | 08:09 PM
rdssk8rcs1's Avatar
Default map sensor
our map sensors have a vacume atached to it?
is it common for map sensors to go bad in a turboed car?
Old Oct 9, 2006 | 08:43 PM
JasonST's Avatar
Default Re: map sensor (rdssk8rcs1)
In turboed cars u need a certain type of map sensor, one that can read the boost. I'm not sure exactly which one ya need but plenty of ppl on here should know. Bump!
Old Oct 9, 2006 | 08:57 PM
rdssk8rcs1's Avatar
Default Re: map sensor (JasonST)
yeah i know that, n/a cars have a basic one that cant read over barametric presure, and turboed cars depending on how much boost you runn yo get anything from a 3 bar to a 5 bar map sensor....i have a 3 bar....but its not reading right and im trying to find the cause......
Old Oct 9, 2006 | 09:58 PM
Sack Master's Avatar
If your ecu programming is setup to read boost a stock map sensor is cool to about 12psi. After 12psi it will stay the same. Computer won't know if you are running 12 or 18 psi. That could definitely be a problem. As far as going out. Not saying it doesn't but it shouldn't.
Old Oct 10, 2006 | 06:43 AM
rdssk8rcs1's Avatar
Default Re: map sensor (Sack Master)
yeah, well my car was tuned and running fine then recently it has been running lean.....and i found that the map sensor is only picking up on 5.3 pounds of boost when im running 7 and its even worse if i run 15 pounds.....
krugozor
Feb 21, 2011 08:38 PM
H-allmotorda9
Feb 7, 2010 07:29 PM
SilverPanda
Oct 9, 2007 01:16 AM
See Are X
Oct 13, 2005 04:10 PM
B16Civic93
Apr 2, 2005 09:39 AM
