Major V-tec crossover problem?
Old Apr 20, 2005 | 03:51 PM
  #51
DOHCarp's Avatar
Default Re: Major V-tec crossover problem? (DOHCarp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCarp &raquo;</TD></TR><TR><TD CLASS="quote">Alright I hooked a oil pressure gauge right up to the vtec oil pressure sending unit, and it has no pressure! only a little bit of oil comes out through the nylon tube, and then when I hit vtec manually a little more oil jumps out, but not enough to fill the line.
So my question is should I have the same oil pressure at the v-tec oil pressure sending unit as I do at the stock oil pressure sending unit?</TD></TR></TABLE>
bump
Old Apr 20, 2005 | 04:57 PM
  #52
DaveF's Avatar
i believe the only time it has pressure at the test port is when vtec is enguaged.
Old Apr 20, 2005 | 06:24 PM
  #53
Blown90hatcH's Avatar
So my question is should I have the same oil pressure at the v-tec oil pressure sending unit as I do at the stock oil pressure sending unit?</TD></TR></TABLE>I will try and find time to test this out on a local car here and post my results.
Old Apr 20, 2005 | 06:42 PM
  #54
DOHCarp's Avatar
Default Re: Major V-tec crossover problem? (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">I will try and find time to test this out on a local car here and post my results.</TD></TR></TABLE>
That would be greatly appreciated!!!! The way I look at it is Vtec needs oil pressure to start so wouldn't the vtec oil sending unit have pressure at it all the time to see if its safe to cross over?
Old Apr 21, 2005 | 06:38 AM
  #55
DaveF's Avatar
Default Re: Major V-tec crossover problem? (Dturbocivic)
https://honda-tech.com/zerothread?id=639633
Old Apr 21, 2005 | 07:44 AM
  #56
underpressure02's Avatar
chad if you want we can try my aem this weekend see if that make a difference. Since I do not believe it matters if the car is warm and so on for vtec to work. Let me know
Old Apr 21, 2005 | 07:53 AM
  #57
Doodoo's Avatar
Have you tried switching to a known good solenoid? It seems to me that it is mechanically malfunctioning. Have you tried disassembling the solenoid?
Old Apr 21, 2005 | 08:46 AM
  #58
DOHCarp's Avatar
Default Re: Major V-tec crossover problem? (Doodoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doodoo &raquo;</TD></TR><TR><TD CLASS="quote">Have you tried switching to a known good solenoid? It seems to me that it is mechanically malfunctioning. Have you tried disassembling the solenoid? </TD></TR></TABLE>
Not only did I try changing selenoids when that didn't work I changed heads.
Chad I might have to take you up on that offer this weekend just to make completely sure its not the engine managment.
CeeJayy
Jul 27, 2007 01:36 PM
lsvtecna
Jul 23, 2006 10:55 PM
04civic17L
Honda Civic (2001 - 2005)
Jul 12, 2006 01:48 PM
crxkenny
Dec 21, 2002 08:10 AM
