precision sc32
Old Feb 23, 2003 | 10:07 PM
vtecbluesi's Avatar
Default precision sc32
from what i've read this is what to go with, so i have a couple of questions about it: how many of you guys are running this turbo, i plan on getting it will the .63 ar. is it good for street use and the occasional track days. how much hp is it good for, im shooting for 380whp on high boost. my setup will be with a b16 block bored to 84mm with 9.1 compression and goldzilla sleeves, with stock head for now. how many pounds of boost do you guys think it will take to reach 300whp? 380whp? thanks for your help on this guys.
Old Feb 23, 2003 | 10:13 PM
bottlefedb18c1's Avatar
Default Re: precision sc32 (vtecbluesi)
i went with the bigger sc61 and all of there work is but thats all i can help with for now and there customer service is the best
Old Feb 23, 2003 | 10:36 PM
gsrt's Avatar
Default Re: precision sc32 (boostfedb18)
what is your set up? i am going to buy sc61 too. nut i am not sure . is this too big for my set up? thanks
Old Feb 23, 2003 | 10:52 PM
*Boostwerks*'s Avatar
I will be running the SC32 initially with my Built ZC setup. If I feel that I can safely run a larger turbo, I will upgrade to the SC34 for the sake of it's better compressor map.
The SC32 has a weird compressor map (can see at the turbonetics site).
For this reason, I would look into the SC34. It should be perfect for your goals, and give you room to expand if you feel so inclined.
If you are sure as hell you don't want anymore power in the future, and would rather have a little quicker spool, I would look into the SC50...
myownworstenemy
Mar 21, 2015 10:46 AM
legenddriver
Aug 18, 2006 11:19 PM
steve96accord
Apr 8, 2006 04:36 PM
hondaspeder
Sep 8, 2003 01:12 PM
MUGENTYPER
Mar 26, 2003 08:30 AM
