LS/VTEC Tech
Old Nov 21, 2003 | 10:03 PM
99B16Si's Avatar
Default LS/VTEC Tech
what happens if the 1/8npt plug on the bottom of the head doesnt seal/or isnt plugged at all. is it possible that itll leak THRU the headgasket down the back of the block....just curious. ive heard a few people say this can happen but it seems kinda tough for oil pressure get by 70+psi of torque bolting the head to block. fill me in. thanks
Old Nov 22, 2003 | 12:11 AM
1FSTCPE's Avatar
Default Re: LS/VTEC Tech (99B16Si)
yes oil will leak,if you don't seal or install 1/8npt in bottom of the head.because on an l/s motor there is no block underneath the fitting,thats where the gsr vtec solenoid gets its oik pressure from.
Old Nov 22, 2003 | 06:21 AM
99B16Si's Avatar
i never noticed that...so if u were to turn the whole motor upsidedown u can actually see that fitting when the head is already bolted to the block???? can u actually access the allen key plug with the head on the block already?
Old Nov 22, 2003 | 09:10 AM
HybridKOOP's Avatar
Default Re: (99B16Si)
Yes there is block material under the hole in the head for the VTEC oil pressure, it's just that on a LS block theres no opening for the oil to go through - it's just solid...
If you don't plug the head, it will manage to seep it's way out between the headgasket and make a mess on the side of the block.
Old Nov 22, 2003 | 09:32 AM
99B16Si's Avatar
Default Re: (HybridKOOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP &raquo;</TD></TR><TR><TD CLASS="quote">Yes there is block material under the hole in the head for the VTEC oil pressure, it's just that on a LS block theres no opening for the oil to go through - it's just solid...
If you don't plug the head, it will manage to seep it's way out between the headgasket and make a mess on the side of the block.</TD></TR></TABLE>
yea thats what i thought, but im starting to think the link is from me not removing the rivets in the headgasket. i didnt know this was necessary as i have never done it before and never had this problem
Old Nov 22, 2003 | 03:54 PM
1FSTCPE's Avatar
underneath the head half of the 1/8npt plug is exposed.you ca feel it with a finger but u can't seal or fit an allen in there
Nisif
Sep 16, 2014 06:25 AM
B-B-K
Jun 10, 2005 06:14 AM
Mr.DC2TurBo
Feb 16, 2005 12:57 PM
SLow-Side
Nov 21, 2004 03:14 PM
Trooper
Nov 17, 2003 07:25 PM
