Ls-Vtec T or Gsr T'
Ls-Vtec T or Gsr T'
im going to have a bottom end built up over this winter for boost, but im having troubles deciding which bottom end to go with. For reference ill be usuing a type r head, intake manifold, and virtually anything else other then the type r bottom end. Ive been debating between just having a gsr bottom end built or going with a b18a and then usuing a golden eagle ls-vtec kit. What type of power difference would there be between the two set-ups on an identical turbo set-up?
They would both average out to being the same price sense gsr blocks sell for 200-400 and the b18a's can be found for 50-100, but the b18a would require an ls-vtec kit. Either way ill be usuing all my R parts from my swap besides the bottom end so im left debating the subject.......'
thoughts, opinions, suggestions ?
goal is 300whp daily boost, 450whp high boost
also debating between sleeving it or not, most i want to push is 450whp, ill be happy with 300whp low boost and anything 400+ high'
Modified by digital sol at 11:20 AM 11/5/2006
Re: Ls-Vtec T or Gsr T' (digital sol)
Do the gsr if you already have it.It's a much cleaner set up.You will never see the difference of a few cc's.If you have a good engine management and tune than you should be fine with stock sleeves at that hp.
476 whp / 323 tq @ 17 PSI
Re: Ls-Vtec T or Gsr T' (NJIN BUILDR)
GSR turbo, but with the LS bottom end you will definately get more torque. With a straight GSR, you will get more reliability. If you have the money, it will always be worth it to re-sleeve. YOU WILL WANT MORE BOOST TRUST ME.
Re: Ls-Vtec T or Gsr T' (JDM turbo DC)
yeah just sleeve it noe. it will leave you plenty of room to grow and its a lil safe gaurd for your motor. boost is ADDICTIVE!!
do it right or do it twice
id go with the gsr K.I.S.S.
keep it simple sucka
its more of a preference thing......
If I where you I would get the block sleeved and put the LS crank inside the GSR block and have a RLZ or similar block girdle installed so you can still rev it as high as the GSR..... but that’s just me
Re: Ls-Vtec T or Gsr T' (VtecnTurbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecnTurbo »</TD></TR><TR><TD CLASS="quote">yeah just sleeve it noe. it will leave you plenty of room to grow and its a lil safe gaurd for your motor. boost is ADDICTIVE!!
keep it simple sucka </TD></TR></TABLE>
You got that right.
You got that right.
Re: Ls-Vtec T or Gsr T' (aaronISthrowed)
yep boost is a drug, you get a small taste and want another and another and another
so if you do it right you can have a motor take you from 5 to 25 psi and it gives you a wide range out power options
200whp to hell 600+whp
thats just the differences between a sleeved and a non sleeved oem sleeve block
