ls/v turbo no power
ls/v turbo no power
I just got my car running, built lsv turbo. I have an intank aeromotive 340 pump, with dsm 450's, with a base map tune on chrome. I was driving for the first time tonight and got on it but it felt like very LITTLE power. I thought i had a boost leak but i looked at the boost gauge and it got up to 5psi before i let off and the bov works so i know its getting boost but it just seems like a beefy all motor lsv. I've been in plenty of turbo cars and i know how its supposed to feel when boost kicks in but this doesnt pull or anything. Wont even break tires loose in 1st! Now I DO have cel on for tps,coolant temp, and iat.. would those cause it to have NO power under boost? If you need any more information just ask i will tell you what you want to know, just wanted to get out the basics of whats going on.
Re: ls/v turbo no power
I'm on getting the codes fixed. It only saw boost to make sure everything is working properly; wg, bov etc. but noticed it has no power. Can these codes make that happen? Or is there something else I need to look at? I will be getting a tune as soon as i can but need to get the kinks fixed first. Just wondering why there seems to be no power.
Crome, my buddy has a good tune on his car. A little different setup but copied it onto my chip and adjusted for what I have as close as possible without drive tuning it.
every engine is different, you cant just copy a tune of someone with a similar set up and go beat on it. fix the CEL's and get it tuned
X2BOARD
06-18-2003 10:14 AM
