Ls turbo setups
Old Jul 13, 2004 | 09:39 AM
  #76
.::Lee::.'s Avatar
Default Re: Ls turbo setups (xenocron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">
Anything in particular about the actual head design that would affect this making someone want to actually upgrade to a b18b head?
From what I've heard, the difference in hp ratings between the B18a and the B18b comes from the head. Apparently it's a little less restrictive, but I can't remember for sure what it was.
Old Jul 13, 2004 | 10:04 AM
  #77
Mr.DC2TurBo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">So then upgrading to the Crower turbo cams and getting a Skunk2 or JG intake mani would be good upgraded for the b18a?
It all depends on what you are using the car for, track only or daily driving. The cams will give you a really rough idle so these are things to consider also.
Old Jul 13, 2004 | 11:17 AM
  #78
ritalin
Guest
Posts: n/a
Default Re: Ls turbo setups (Mr.DC2TurBo)
Damn I need to go to the junkyard more often. I don't think aggressive cams would hurt my daily commute too much. I drive 1.5mi to work.
Old Jul 13, 2004 | 11:25 AM
  #79
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.DC2TurBo &raquo;</TD></TR><TR><TD CLASS="quote">
It all depends on what you are using the car for, track only or daily driving. The cams will give you a really rough idle so these are things to consider also.</TD></TR></TABLE>
The turbo cams are like 190/190 @ .050 for duration, how is that going to give you a rough idle? It's higher than stock by 3 degrees. I've driven a turbo car with crower 404's before and the idle was fine.
Old Jul 13, 2004 | 02:24 PM
  #80
xenocron's Avatar
Default Re: Ls turbo setups (boosted92)
Great info guys!
Also...does anyone have experience upgrading the Throttle Body...to like a GSR or H22?
Since the head doesnt flow much as it is, to me it wouldnt seem like a sensible upgrade, unless you got a great price on one...but i dunno really.
Old Jul 13, 2004 | 02:29 PM
  #81
mildly.interesting's Avatar
I've got a JG throttle body on mine, portmatched to a stock LS mani, and it flows well...
Old Jul 13, 2004 | 02:44 PM
  #82
omahaturbocivic's Avatar
Default Re: (mildly interesting)
Here is a friends car I dyno tuned last week and I helped build. It was hitting 325 conistantly on the street simulations but the power pulls tend to read a bit lower and it was getting pretty heat soaked. It actually hit 321 on this pull at 7200 as well if you look at the sheets below. Remember this in on a Mustang dyno too, on a dynojet it would be about 15% higher. The setup was a b18a with srp pistons and eagle rods, t3/to4e 57trim .63/.60, precision 780cc injectors, crane turbo cam, crane springs and retainers, gm 3bar map sensor, and UBERDATA 1.66. The lower rpms were a bit rich as you can see below but I cleaned them up on the street right after we dynoed (I changed him from Uberdata 1.65 repack 3 to 1.66 at the dyno so the partial throttle was a bit off).
Old Jul 13, 2004 | 02:59 PM
  #83
NotPhilTran's Avatar
Default Re: (omahaturbocivic)
chris is my hero!
your building my next engine
Old Jul 13, 2004 | 04:41 PM
  #84
untitled's Avatar
Default Re: (stolencrx)
subscribing.
Old Jul 13, 2004 | 07:05 PM
  #85
Superesc's Avatar
Default Re: (1.8LS-T)
One of the best thread (most needed thread hehe)!!! I haven't gone to the dyno and wasn't sure how far I can push my setup. Keep it coming!!
Old Jul 13, 2004 | 08:03 PM
  #86
ritalin
Guest
Posts: n/a
Default Re: (Superesc)
I like those numbers. I want to achieve 300whp but also keep tq as close to hp as possible.
Old Jul 13, 2004 | 11:52 PM
  #87
B18bEK's Avatar
Default Re: (ekhatch00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekhatch00 &raquo;</TD></TR><TR><TD CLASS="quote">I like those numbers. I want to achieve 300whp but also keep tq as close to hp as possible. </TD></TR></TABLE>
at 290hp i was making 270tq ... pretty close ... alot better than any stock vtec motor!
Old Jul 14, 2004 | 02:05 AM
  #88
ritalin
Guest
Posts: n/a
Default Re: (B18bEK)
Yeah I see a lot of gsr turbo'd setups but they have low tq. Last one I saw had 300whp and 200wtq. It wasn't very impressive.
Old Jul 14, 2004 | 06:41 AM
  #89
brickonwheels's Avatar
What about the ls motor allows it to produce so much more torque than say a gsr?
Old Jul 14, 2004 | 07:57 AM
  #90
mos's Avatar
mos
Default Re: Ls turbo setups (shermanyang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang &raquo;</TD></TR><TR><TD CLASS="quote">
90-91 B18a = ODB0
92-93 B18a = ODB1
94-95 B18b = ODB1
96-01 B18b = ODB2
90-91 B18a 130hp@6000/121tq@5000
92-01 B18b 140hp@6300/126tq@5000</TD></TR></TABLE>
94-01 B18b is rated by honda at 142hp... but you know how worthless manufacturer quoted figures are. It's probably just because of the less restrictive airfilter on the DC. Better to go with your figures.
Old Jul 14, 2004 | 08:34 AM
  #91
integraracer94's Avatar
Default Re: Ls turbo setups (mos)
I made 336hp 308tq on pump gas @ 16psi
60trim turbo To4E housing
SST manifold
Mild P&P
Hondata s200
Ross pistons / Crower rods
Old Jul 14, 2004 | 09:11 AM
  #92
ATrin's Avatar
Default Re: Ls turbo setups (integraracer94)
Alright guys this is my future setup let me know how you think it'll do:
96 B18B
HKS GT-SS turbo internal w/g
Hks cast manifold
Greddy front mount i/c
walbro fuel pump
RC 550's
Hondata S200
Hks SSQ bov
The turbo is compared to a Garrett GT28, but a little bigger is all ball bearings and its brand spanking new! I think this turbo mated with the already torquey LS motor, this thing will have mad torque! anyone else with a similar setup??
Old Jul 14, 2004 | 12:10 PM
  #93
brasilstreet's Avatar
should i run the regualr apexi n-1 cat back exhasut on my ek hatch with a b18b swap boosted? and a 2.5 inch downpipe or should i get the turbo apexi n-1 muffler and a custom 3 inch piping done and have a 2.5 downpipe ? what should i get for turbo exhasut i have a 2.5 down pipe i wont change that ?
Old Jul 14, 2004 | 12:18 PM
  #94
.::Lee::.'s Avatar
Default Re: Ls turbo setups (ATrin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATrin &raquo;</TD></TR><TR><TD CLASS="quote">Alright guys this is my future setup let me know how you think it'll do:
good
Old Jul 14, 2004 | 12:21 PM
  #95
Toda Party's Avatar
Default Re: Ls turbo setups (Ibiza)
lol
Old Jul 14, 2004 | 01:01 PM
  #96
boosted92's Avatar
Did you run that 11.8 @ 121 with 336 WHP?
Old Jul 14, 2004 | 01:28 PM
  #97
adseguy's Avatar
just subscribing. It's so awesome to see Turbo LS's pushing close to or more then 300WHP on stock internals. Those have got to be some fun cars. I'll post here in 2 months when I'm done. Here's the setup:
Stock as a rock block and head
t3/t04e 57 trim .60/.63
speedpartsrus.com 30x6.5x2.75 IC
neukin.com custom equal length manifold
tial 38mm
turbo XS type H RFL BOV
3" DP
catless 3" exhaust (my dad works with the EPA...he loves me for it )
DSM 450cc
Walbro 255 HP
2.5-2.25" IC piping (still don't know)
Sportin Uberdata!
Hopin' to make 280WHP...then save money get internals/injectors and push 400WHP and call it a mother f*ckin GOOD DAY!
Old Jul 14, 2004 | 03:05 PM
  #98
Superesc's Avatar
Default Re: Ls turbo setups (adseguy)
Was wondering what kind of clutch you guys are using too?
Old Jul 14, 2004 | 03:40 PM
  #99
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Ls turbo setups (Superesc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superesc &raquo;</TD></TR><TR><TD CLASS="quote">Was wondering what kind of clutch you guys are using too?</TD></TR></TABLE>
I'm using a CM Stage 3. Seems to be holding great. I'm running 8psi.
Old Jul 14, 2004 | 06:32 PM
  #100
anyone else what clutch you got ? im putting my b18b in my ek hatch next week and im going to boost it so i got a act 12.5 lbs flywheel and now i need a clutch but i only have 300-350 to spend where can i get a clutch for that price thats great on street forced induction cars?plz
