Ls turbo setups
Old Jul 11, 2004 | 04:24 PM
  #26
DRAGLS's Avatar
Default Re: (Mr.DC2TurBo)
i rebuilt the motor with all original parts except for the srp pistons, I am in the peocess of building a second LS ported head,ss under cut valves, crower 404 cams,
dan parramore valve springs,sleeved block 81mm, eagle rods,ross pistons 8.5comp, cometic 2mm headgasket few other things just need a few gaskets and i can do the swap.
Old Jul 11, 2004 | 04:25 PM
  #27
Mr.DC2TurBo's Avatar
Default Re: (DRAGLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAGLS &raquo;</TD></TR><TR><TD CLASS="quote">LS, srp 8.5 pistons, stock rods, skunk int mani , fmu , 440cc inj, t3/t04e 50-trim</TD></TR></TABLE>
That's incredible. I have a similar setup:
srp 9.5
eagle rods
skunk im
550cc
t3/t4e 57 trim
hondata
I wanted 350hp around 15-17psi but most of the dynos I have seen don't even come close unless I'm boosting around 2Xpsi for LS motors (20psi just seem soo much without a block being sleeved). Congrats again
Old Jul 11, 2004 | 04:26 PM
  #28
DRAGLS's Avatar
Default Re: (brickonwheels)
stock clutch that maybe a problem, u better start saving up its not going to last
Old Jul 11, 2004 | 04:36 PM
  #29
brickonwheels's Avatar
How long do you think i can go?
Old Jul 11, 2004 | 04:38 PM
  #30
And you think 240 is an attainable number at 6.5 psi even with the smaller of the precision series, the sc50?
Old Jul 11, 2004 | 04:43 PM
  #31
DRAGLS's Avatar
same turbo i am running i made 334 at 14psi
Old Jul 11, 2004 | 04:48 PM
  #32
ritalin
Guest
Posts: n/a
Those are some nice setups. I don't think it will be too hard to get 300whp. I also want to make some good tq though.
Old Jul 11, 2004 | 04:54 PM
  #33
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAGLS &raquo;</TD></TR><TR><TD CLASS="quote">same turbo i am running i made 334 at 14psi</TD></TR></TABLE>
What kind of a dyno was it? dyno jet, dynopack, etc?
Old Jul 11, 2004 | 04:55 PM
  #34
DRAGLS's Avatar
dyno jet
Old Jul 11, 2004 | 07:08 PM
  #35
Toda Party's Avatar
stock longblock, oem headgasket
maxrev kit (log mani, 2.5" downpipe, cat, 3" cat back)
t3/t4 57 trim
hondata
12.5psi 300 whp 270 tq on an old school clayton 4wd dyno (neetronics, toronto)
g/l ls turbo torque ownzzz
Old Jul 11, 2004 | 08:04 PM
  #36
ritalin
Guest
Posts: n/a
Default Re: (Toda Party)
What rpm do you spool at? I was going to go with a smaller t3 for quick spool but if you spool decent with your t3/t04 I might go that route.
Old Jul 11, 2004 | 08:12 PM
  #37
Toda Party's Avatar
Default Re: (ekhatch00)
i "started" to spool from what i recall (i sold the kit so its been a while) right around 3-3200 rpm, i would reach 12.5 psi by 4-4300 rpm in that area... revved it out to 7100 (stock LS longblock)... on 22x8x15's bouncing the limiter in 4th i was running low 12's @ 118, best et of an 11.9 @ prolly 2300 lbs or so (with driver)
Old Jul 11, 2004 | 08:44 PM
  #38
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toda Party &raquo;</TD></TR><TR><TD CLASS="quote">stock longblock, oem headgasket
t3/t4 57 trim
hondata
g/l ls turbo torque ownzzz</TD></TR></TABLE>
clayton dyno are known to produce higher hp/tq when compared with dyno jet.
Old Jul 11, 2004 | 08:49 PM
  #39
Toda Party's Avatar
who cares, all that matters is the et and trap right
Old Jul 11, 2004 | 09:59 PM
  #40
shermanyang's Avatar
setup is:
motor setup:
b18b1, eagle rods, je pistons, dart sleeves, arp bolts/studs, oem bearings, skunk2 intake mani, aem cam gears, ngk plugs gapped .029
turbo setup:
turbonetics t3to4e .63/.60 57trim, drag mani(yeah i know...but i had to sell my equal length mani for $$$), precision 750hp fmic, msd 3bar map, msd 1008cc injectors, blitz ss bov, tial wg, custom IC piping (2"-&gt; 2.25"-&gt; fmic-&gt; 2.5"), custom 2.5"-&gt;3" dp, custom oil cooler, TR&D 3" turbo exhaust, 3" test pipe, AEM EMS 30-1000 w/wideband.
i think that's about it.
on a pretty shitty tune(only 4 pulls total after creating a base map since AEM does not support MSD injectors) i only made this much with fouled pulls, heat soaked motor, etc...
Old Jul 12, 2004 | 01:02 AM
  #41
ritalin
Guest
Posts: n/a
Default Re: (shermanyang)
What do you guys think of inlinepro? Looked like some pretty decent stuff.
Old Jul 12, 2004 | 05:49 AM
  #42
DaX's Avatar
DaX
Loved
Community Favorite
I'm pushing 8psi on my Turbo LS [EH2] and the butt dyno and everyone says I'm making 220-250whp right now. It pulls hard and I love it. You can see pics and my setup here:
https://honda-tech.com/zerothread?id=913515
Old Jul 12, 2004 | 07:11 AM
  #43
b18b98's Avatar
Default Re: (DaX)
check my signature.
Old Jul 12, 2004 | 08:11 AM
  #44
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.DC2TurBo &raquo;</TD></TR><TR><TD CLASS="quote">That is one hell of a LS... 334 at only 14 psi with such an average size turbo??? I have always wondered about this one, if an LS making 300 hp vs a GSR making 300hp, which one would win? I understand a gsr would go through the gears faster but an LS would make more tq. So what is better?</TD></TR></TABLE>
I would think it depends more on the overall torque curve and not just the peak numbers.
A LS might make more peak torque but a GS-R can rev higher and get there faster...so I'm guessing GS-R with all HP peak #'s being consistant.
What Intake manifold are you LS guys running to make good #'s? RevHard? Skunk2? JG Edlebrock? Others?
This will be one of my next upgrades as I dont think my B18a breathes very well. Thinking about attaining a B18B head and Skunk2 IM with a GSR throttlebody.
Also, does hondata make the IM gasket for the non-vtec head?
BTW...I'm thinking I'm close to 190 whp @ ~8-9psi on my b18a with a SC34/inline pro manifold. I need to get this bitch dyno'd as someone else made 202 HP / 189 TQ on my TurboEdit map this past weekend on the same motor/car @ 9 psi.
Old Jul 12, 2004 | 12:26 PM
  #45
EG-6Ghost's Avatar
Do you need to put block sleeves if your running 300whp or more?
Old Jul 12, 2004 | 12:31 PM
  #46
1 POINT 8's Avatar
i have a 98 ls with cp pistons 9:5:1 compression, eagle rods,block gaurd drag kit and an sc61 . st00pid told me he could make the 430hp that i wanted but im not going to tune in anymore. well with saying that the motor and turbo kit are for sale
Old Jul 12, 2004 | 12:32 PM
  #47
boosted92's Avatar
Default Re: (EG-6Ghost)
That 334 WHP number is converted to STD, so it's more along the lines of 315-320 WHP SAE. Still a nice number from an LS.
Old Jul 12, 2004 | 12:34 PM
  #48
EG-6Ghost's Avatar
Default Re: (boosted92)
what about the internals I want to change the rods and pistions (SRP) just in case ...just to be on the safe side is it worth it?
Old Jul 12, 2004 | 12:43 PM
  #49
roydogg's Avatar
I see that your putting well over 300 on 440cc injectors . I thought that they max out at 300whp, I wonder what the duty cycle is?
Old Jul 12, 2004 | 12:46 PM
  #50
DRAGLS's Avatar
Default Re: (roydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roydogg &raquo;</TD></TR><TR><TD CLASS="quote">
I see that your putting well over 300 on 440cc injectors . I thought that they max out at 300whp, I wonder what the duty cycle is?</TD></TR></TABLE>
I am using a FMU
