Ls turbo
Old May 17, 2005 | 12:17 PM
  #51
IS teg's Avatar
Default Re: Ls turbo (jdmhonda)
I was wondering what size intercooler you have on your ls integra length, width, and height.
Old May 18, 2005 | 05:46 PM
  #52
IS teg's Avatar
bump
Old May 19, 2005 | 07:37 PM
  #53
IS teg's Avatar
Is there anyone that can tell me what size intercooler will fit on a 95 ls integra?
Old May 22, 2005 | 11:12 PM
  #54
Justateg's Avatar
Default Re: (IS teg)
It depends on if you want to looses your bumper. You can make a lot of stuff fit, depends on how much modifying you want to do.
Old May 26, 2005 | 05:29 PM
  #55
IS teg's Avatar
Default Re: (Justateg)
For an intecooler I don't want to loose my bumper I just want something to fit with less modification as possible. Do you know of any size height, width, and length of intercooler that would have a good fit on a 95 integra?
Old May 26, 2005 | 05:40 PM
  #56
jdm-ray's Avatar
From: home of Marciano/Haggler, city of champions, MA
i would think 25 inches wide (20 inch core), 8-10 inches high, 2.5 inches thick
Old May 26, 2005 | 05:45 PM
  #57
jdm-ray's Avatar
measure from your radiator support- midway thru the bottom lip on the bumper for height. if you can fit 12in. it would look hot
Old May 26, 2005 | 06:23 PM
  #58
Na-Spirit's Avatar
I'm useing a 48/60 57trim, spools good
Old May 26, 2005 | 06:29 PM
  #59
jdm-ray's Avatar
Default Re: (mugenknockoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenknockoff &raquo;</TD></TR><TR><TD CLASS="quote">I'm useing a 48/60 57trim, spools good</TD></TR></TABLE>
must be fun for city driving. whens your spool and how much hp/trq?
Old May 29, 2005 | 10:02 AM
  #60
IS teg's Avatar
How much whp are you running? I'm trying to run 250whp. I'm kind of confused about the ar numbers. I wanna know which is the best setup for what I'm looking for?
Old May 29, 2005 | 08:09 PM
  #61
Rico's Avatar
I've had my ls turbo for almost two yrs. Making 286/256 @ 18 lbs. and its daily driven everyday from school to work. All it really comes down to is the maintance and the tuning.
Old May 29, 2005 | 08:16 PM
  #62
s2kdre's Avatar
Default Re: Ls turbo (IS teg)
you can stay at low boost, on a stock motor, 15psi and below.
Old Jun 1, 2005 | 05:29 PM
  #63
IS teg's Avatar
What size turbo could I use for my stock ls motor? Also which turbo kit would you recomend?
Old Jun 1, 2005 | 10:47 PM
  #64
jdm-ray's Avatar
i would say 55 a/r exhaust turbine with a 63 a/r compressor turbine. that would spool around maybe 3500 rpm. anyone correct me if i'm wrong
Old Jun 1, 2005 | 11:36 PM
  #65
Na-Spirit's Avatar
i havent really looked at where im getting full boost...4k i believe, ive been doing 12-13psi for the past 1300 miles on it with 173,000 on the motor all stock and yes im a fool....been to the track 4 times now. im useing xenocron's tune.
JDM-Rota
Dec 20, 2005 11:36 PM
hypnothaiz
Jun 21, 2004 06:51 PM
lsracer27
Apr 9, 2004 08:12 PM
wankerman28
Jul 16, 2002 05:45 PM
VoltageLS
Apr 7, 2002 01:40 PM
