gsr pistons in a ls block someone help please
Old Sep 24, 2003 | 09:06 PM
sadcivic's Avatar
Default gsr pistons in a ls block someone help please
ok my question is can you use gsr pistons in a ls motor? stock ls head? is there an advantage or disadvantage?
Old Sep 24, 2003 | 10:17 PM
Mochanic's Avatar
Default Re: gsr pistons in a ls block someone help please (sadcivic)
yes, you can interchange the pistons, but if your gonna do that, I would go with ITR or CTRs they will yield higher compression.
Old Sep 24, 2003 | 11:46 PM
mmuller's Avatar
Mad Scientist
Default Re: gsr pistons in a ls block someone help please (Mochanic)
you'll only get about 9.6 comp. with that, as sayd above go for something more radical
Old Sep 25, 2003 | 12:30 AM
dc4sleeper's Avatar
I agree. Dont waste the time and money, get the itr or ctr pistons. Spend the money on the vtec head.
Old Sep 25, 2003 | 06:06 AM
pro1342's Avatar
You have to run GSR rods, or modify the LS rods for it to work.
Old Sep 25, 2003 | 06:48 AM
sadcivic's Avatar
Default Re: gsr pistons in a ls block someone help please (pro1342)
i got ls crower rods and arias gsr pistons low compression. had a vtec head on it but floated a valve so now i am trying to run my car with the stock head. i have boost
Old Sep 25, 2003 | 08:00 AM
Mochanic's Avatar
Your very right about this... Its been a little while since I built this combo.
Its very easy to have your LS rods modded to accept the GSR, ITR, CTR pistons.
Have a local machine shop mill 1mm per side of off the small ends of the rods and your done.
stoney0078
Jan 30, 2009 06:08 AM
delsol456
Mar 5, 2008 05:50 PM
GSE980
Jul 7, 2006 02:54 PM
tfalconier
Aug 18, 2004 07:56 PM
JDMvtecDRAGSTA
12
Feb 4, 2004 04:12 PM
