LS Pistons in a b16???
Old Jun 19, 2005 | 12:01 PM
Mike@CCT's Avatar
Formerly Mike@TSR
Default LS Pistons in a b16???
Would it work for a near 9:1 compression ratio? Would be used for a low boost (lower than 10psi)
Old Jun 19, 2005 | 12:03 PM
Boosted Chemist's Avatar
Default Re: LS Pistons in a b16??? (Mike@TSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike@TSR &raquo;</TD></TR><TR><TD CLASS="quote">Would it work for a near 9:1 compression ratio? Would be used for a low boost (lower than 10psi)</TD></TR></TABLE>
if you are running less than 10 psi, just keep the stock b16a slugs and live a 10.2:1
and have more fun
Old Jun 19, 2005 | 12:39 PM
tegturbo's Avatar
ya you could run more boost with the ls pistons
Old Jun 19, 2005 | 12:42 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (1.7turbo)
unless you have custom rods made it wouldnt work... the ls has an 89mm stroke, the b16 doesnt
Old Jun 19, 2005 | 12:52 PM
boosted92's Avatar
Default Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">unless you have custom rods made it wouldnt work... the ls has an 89mm stroke, the b16 doesnt</TD></TR></TABLE>
B16 has a different rod length and deck height to compensate. All B-series pistons are interchangeable, except for the B20 pistons, but if you have another motor sleeved to 84mm you could run B20 pistons. Don't know why you'd do that, but you could.
Old Jun 19, 2005 | 01:56 PM
tegturbo's Avatar
Default Re: (boosted92)
ya i had b18b pistons in my b17a worked good.
Old Jun 19, 2005 | 01:57 PM
wantboost's Avatar
Who is Mr Robot?
hmm. i just dont personally get why you would goto all of the trouble to pull a motor apart and replaec the parts with stock ones. Just upgrade to forged parts while you are at it.
I just got my motor done like 10 minutes ago and i couldnt imagine going through the PITA to replace stock parts
Old Jun 19, 2005 | 02:32 PM
brickonwheels's Avatar
Well, lets see. Stock ls pistons you could get for what? $50? and after market arias pistons, maybe 350, if you are lucky.
Old Jun 19, 2005 | 02:47 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (brickonwheels)
and which ones will last longer nder high boost/rev/abuse situations...
Old Jun 19, 2005 | 03:14 PM
hmmm...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">and which ones will last longer nder high boost/rev/abuse situations...</TD></TR></TABLE>
That's interesting...yes.
Old Jun 19, 2005 | 03:16 PM
wantboost's Avatar
Who is Mr Robot?
lol. i didnt even think about that one.
true, for low boost setups the lower compression ratio is a good thing and even i have some laying around. I guess for a budget low power build up they would be fine
Old Jun 19, 2005 | 03:38 PM
project dc2's Avatar
i woudlnt bother. i'd keep the b16 compressoin ratio. plenty of people have ran stock compression and still made power and lasted.
when it comes down to it. its about the tune. and how you drive you car.
i personally beat my car everywhere i go. needless to say nothing lasts long for me.
Old Jun 19, 2005 | 04:42 PM
Mike@CCT's Avatar
Formerly Mike@TSR
Default Re: (project dc2)
thanks for all the input guys. I was wondering this because i have a few empty b16 shortblocks laying around with no pistons or rods in them and a junkass turbo kit i can piece together.
One other question tho. Would the small end of the rod be too narrow if i did decide to do this? or would it even matter?
Old Jun 19, 2005 | 06:44 PM
deftones0817's Avatar
Default Re: (Mike@TSR)
i dont see why people replace with stock pistons either. 300 hp is 300 hp no matter what pistons u use. I say shoot for like 250-280 if your going stay stock and leave it there.
Old Jun 19, 2005 | 08:08 PM
TurboJesse
Guest
Posts: n/a
Default Re: (QuickwhipsCRX)
Compression will be less than 9:1 i believe. I ran a b16 with LS pistons..its not a bad idea. Cheap way to lower the compression and not ruin quench like a thick headgasket does.
Old Jun 19, 2005 | 08:26 PM
Mike@CCT's Avatar
Formerly Mike@TSR
Default Re: (PhoenixTurboJesse)
good call. i didnt even think about the quench being better like that.
when you did it, did the pistons adapt to the rods ok? there wasnt too much piston/small end clearance?
Old Jun 20, 2005 | 03:30 PM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike@TSR &raquo;</TD></TR><TR><TD CLASS="quote">good call. i didnt even think about the quench being better like that.
when you did it, did the pistons adapt to the rods ok? there wasnt too much piston/small end clearance?</TD></TR></TABLE>
Not sure..i had a machine shop do it...Just brough the a set of b16 pistons/rods and a set of pr4 pistons/rods and said swap the pistons rods
Old Jun 20, 2005 | 03:49 PM
rioninja's Avatar
Compression will be in the 8.x range. I did this a long time ago on my B16a also. Worked out well. I was a little ****, so i enlarged the valve reliefs before i installed them. Probably not necessary though.
Old Jun 23, 2005 | 03:53 PM
tegturbo's Avatar
mine lspistons fit very good on my b17 rods comp was 175 in all 4 cyc.
Old Jun 23, 2005 | 06:49 PM
red cx's Avatar
im running ls pistons in my b16 right now and i run 19psi all day long. so far it has run pretty damn strong! one thing that does scare me is the valve relief's
Old Jun 23, 2005 | 07:03 PM
tegturbo's Avatar
Default Re: LS Pistons in a b16??? (red cx)
ya i didn't like either
v8killaz
Apr 6, 2010 11:24 AM
Griffin@Camtech
Nov 24, 2005 08:14 AM
hOndafienD 04
Apr 6, 2005 08:42 PM
turboekcivic
Aug 8, 2004 01:25 PM
ensracer
Apr 14, 2004 07:45 PM
