LS CRANK INTO GSR BLOCK
Old 03-31-2007, 11:59 PM
spgcuantik's Avatar
Default LS CRANK INTO GSR BLOCK
thinking of going this route with forged rods, but with stock p72 pistons, i heard that the p72 pistons wont fit with the forged LS rod because of the wrist pin? only the b16 will fit or type r.....the rod im going with is the eagle h-beam any input will help thx u
Old 04-01-2007, 12:01 AM
SlowReaction's Avatar
Default Re: LS CRANK INTO GSR BLOCK (spgcuantik)
why are you going to use a stock piston on a aftermarket rod?
Old 04-01-2007, 06:18 AM
spgcuantik's Avatar
bummmmmmppppppp
Old 04-01-2007, 09:04 AM
reactiondc2's Avatar
Default Re: (spgcuantik)
why would you run stock pistons on a forged rod?what is your ultimate goal?stock gsr pistons arent the best to handle boost and the compression isnt the best for an na application...gotta have a goal in mind otherwise your just wasting money
Old 04-01-2007, 09:17 AM
HiProfile's Avatar
It should be safe to assume you're going with boost, as this is FI.
ALL Honda OEM cast pistons will take a **** (ringlands) before stock LS rods, let alone GSR rods. So I will present this question again:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowReaction &raquo;</TD></TR><TR><TD CLASS="quote">why are you going to use a stock piston on a aftermarket rod?</TD></TR></TABLE>
Old 04-01-2007, 10:09 AM
Default Re: LS CRANK INTO GSR BLOCK (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">It should be safe to assume you're going with boost, as this is FI.
</TD></TR></TABLE>agreed....definately dont waste money on a forged rod if you are using a stock cast piston
Old 04-01-2007, 01:17 PM
spgcuantik's Avatar
yes turbo is my goal, looking to daily drive on 10 pounds reason why i was going with the stock pistons was because this is a budget build. what pistons do you suggest?
Old 04-01-2007, 01:23 PM
spgcuantik's Avatar
oh ya stock bore just rehoned
Old 04-01-2007, 01:46 PM
mportracer33's Avatar
just do stock rods and stock pistons if its a budget build...On 10 pounds the rods won't let loose.
Old 04-01-2007, 01:55 PM
been there done that
doood's Avatar
Default Re: (mportracer33)
dont get stuck on a psi number. set a hp goal. 300whp on stock internals is perfectly doable with a good tune.
Old 04-01-2007, 02:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spgcuantik &raquo;</TD></TR><TR><TD CLASS="quote">yes turbo is my goal, looking to daily drive on 10 pounds reason why i was going with the stock pistons was because this is a budget build. what pistons do you suggest?</TD></TR></TABLE>just run stock internals...if you half *** it and blow the ring lans off the pistons you are gonna have to spend more to rebuild the motor again....do it right or not at all
Old 04-01-2007, 02:23 PM
Adriano's Avatar
Default Re: (reactiondc2)
OR just run stock ls pistons with ls rods (aftermarket or stock) and ls crank on a gsr block.
Adriano
katanamast279
03-16-2009 10:11 PM
.doeboyfresh.
03-04-2008 09:11 PM
whitehatchguy
04-18-2007 06:49 AM
dragEF8
06-16-2004 11:48 AM
tegasaurus
07-04-2003 11:46 AM
Quick Reply: LS CRANK INTO GSR BLOCK
