Piston question
Old Jun 16, 2004 | 02:12 AM
dragEF8's Avatar
Default Piston question
Will b18c1 pistons and rods fit in a b18a? Also, the pistons are 9.0:1 in a gsr, what will they be in a b18a if they fit?
Old Jun 16, 2004 | 03:25 AM
Gerbilo's Avatar
Default Re: Piston question (dragEF8)
I thought the b18c1 was 10.0:1 w/ stock pistons
Old Jun 16, 2004 | 03:37 AM
dragEF8's Avatar
Default Re: Piston question (Gerbilo)
These are JE pistons w/ eagle rods. The guy had them in his GSR...
Old Jun 16, 2004 | 03:41 AM
Gerbilo's Avatar
ahh... check
Old Jun 16, 2004 | 04:00 AM
RPRacing's Avatar
pistons will fit. rods wont unless you get a gsr crank. and for the compression ratio. i am not sure.
Old Jun 16, 2004 | 09:10 AM
IN VTEC's Avatar
You'll have to use either B18A/B rods with the 89mm stroke crank, or you can use the GSR-length rods with the GS-R's 87.2mm stroke crank. You cannot use the GSR-length rods with the 89mm LS crank.
The pistons should be ok. You'll just have to set the piston-to-cylinder wall clearance properly.
Compression ratio will be lower assuming that the piston-to-deck height clearance stays the same. I don't know if it does b/c I've never measured a stock LS block before and I don't know where the JE pistons like to sit on a GS-R block. It's probably .020" to .030" like other forged piston companies I know.
Old Jun 16, 2004 | 11:48 AM
dragEF8's Avatar
Default Re: Piston question (IN VTEC)
I decided to just say screw the 9.0:1 comp. pistons. The 9.2:1 will work fine for me. Thanks for all the helpfl info guys!
Dkahn18
10
Feb 28, 2009 05:40 PM
jennsGSR
Aug 16, 2006 12:17 PM
jeremy.
23
Apr 27, 2005 02:20 PM
syndicate43
Jan 20, 2004 01:15 PM
hitekper4mance
Jul 24, 2002 04:20 PM
