Lowering boost via big Intercooler?
I have a 35mm Tial w/ .65 bar spring. I have stock internals and really don't want to boost this much. My fuel setup (s-afc + dsm 450's on stock pump)/90k b18b isn't high class enough for me to have confidence to boost this much for a daily driver. I do however have a relatively big intercooler. Its' the maxrev intercooler (22x8x3 spearco core). I was wondering how much of a psi drop this would drop the boost? If around .5 bar that would be alright. Should I just buy another spring or upgrade the fuel system? These hondata's are getting pretty fancy. sgT is a tuner and lives around me. Looking to boost this winter.
Any ideas welcomed.
Any ideas welcomed.
As far as I know, it doesn't work that way...you may have a pressure drop of 1.5 lbs, but your waistgate still isin't going to open until it see's .65 bar...it will just take you longer to hit full boost.
I could be wrong though.
[Modified by InfamousRS, 3:28 PM 12/1/2002]
if the intercooler flows better you might increase boost.i went from a very restrictive spearco(drag) to an apexi and the boost went up almost 10 psi!
