Compression vs Leakdown
Old Apr 22, 2004 | 07:38 PM
Mr.Integra's Avatar
Default Compression vs Leakdown
Need a quick answer..
Compression measures cranking pressure. Leakdown measures if you have any leaks in your chamber.
Now here's my question. If my compression numbers are okay, does that mean that my leakdown numbers will be okay too? If not, then why not?
The reason I ask is because I was told that if my compression numbers are fine, then i woudnl't have to do a leakdown test will be okay too.
Old Apr 22, 2004 | 07:39 PM
DragII's Avatar
25 Year Member
Default Re: Compression vs Leakdown (Mr.Integra)
compression tells you if you have a leak
leakdown tells you where the leak is
Old Apr 22, 2004 | 07:42 PM
RTW DC2R's Avatar
leakdown measures the pressure loss in the cylinder and can help tell you WHERE the leak is occuring. compression tests just show the compression when cranking the motor. correct me if Im wrong.
Old Apr 22, 2004 | 07:44 PM
Mr.Integra's Avatar
Default Re: Compression vs Leakdown (DragII)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragII &raquo;</TD></TR><TR><TD CLASS="quote">compression tells you if you have a leak
leakdown tells you where the leak is</TD></TR></TABLE>
then why do some people have perfect compression but their leakdown results sux ***??
Is it because you can have compression that's like 250,250,250,250 and have a leakdown of 10%+ in all four cylinders?
Old Apr 22, 2004 | 07:52 PM
RTW DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Integra &raquo;</TD></TR><TR><TD CLASS="quote">
Is it because you can have compression that's like 250,250,250,250 and have a leakdown of 10%+ in all four cylinders?</TD></TR></TABLE>
that would be fine then. Nothing wrong with that. I forget the OEM tolerance but there will be some loss. Leakdown will not show 0% loss. compression is something that happens when the piston moves to TDC. if you do a compression test, leave the gauge in the spark plug hole, and let it sit, you will lose (leak) pressure from the cylinder. they arent air tight, but they happen so fast that the air doesnt have to leak out when on compression stroke.
Old Apr 22, 2004 | 07:56 PM
DragII's Avatar
25 Year Member
Default Re: Compression vs Leakdown (RTW DC2)
I was a bit too general I guess....here's a decent write up http://www.vclassics.com/archive/leakdown.htm
if compression test #s are high across the board, I wouldn't feel the need to leakdown test it.
self_made
Jun 19, 2005 12:36 PM
Mr.Integra
Apr 22, 2004 07:55 PM
builtprelude
Jan 22, 2004 10:49 PM
