Boost Creep...
Old Sep 30, 2002 | 02:02 PM
FUP23's Avatar
New User
Default Boost Creep...
Im wondering whats going on here ...When you start making boost the gauges reads up to 10 then comes down to about 7.5 it seems to be getting worse ...Wastegate spring maybe ? Anyone ? thanks
Old Sep 30, 2002 | 02:05 PM
pelotudo's Avatar
Default Re: Boost Creep... (Devin17)
You're F/I NOW!!! W00t.
Mine does it cuz I spike w/ the large charge piping. It happens mostly in 2nd/3rd gear. Anyone?
jB
Old Sep 30, 2002 | 03:36 PM
NSX Tech's Avatar
Your losing PSI happens alot get a avc'r and you can set it to RMP boost and never lose PSI..... Alot of turbos bleb off ......... BLA BLA BLA
Old Sep 30, 2002 | 04:41 PM
89civic1.8T's Avatar
Mine does the same thing. I have a Tial wastegate with the lowest spring (5 psi) With my boost controller off it holds steady at 5 psi but when I turn it on it spikes to almost 10 then drops back down to the 6.5-7 range. I have an old Blitz SBC.
Old Sep 30, 2002 | 09:15 PM
turbosol's Avatar
Default Re: Boost Creep... (89civic1.8T)
Boost creep is when you turbo hits your wanted psi and then keeps climbing uncontrolably. It usually happens when you exhaust flows more than your wastegate can vent causing the turbine to spin faster creating more boost. What you are discribing is a boost spike which can usually be fixed with a good boost controller.
BlUAc
May 20, 2006 09:43 AM
turbo95eg6
Jun 12, 2005 12:15 PM
Turbo-charged
Apr 1, 2005 08:32 AM
dallasyoung
Feb 3, 2003 04:56 PM
Cyrio
Dec 4, 2001 07:00 PM
