losing boost
Old Apr 25, 2006 | 03:53 PM
jtracing919's Avatar
Default losing boost
i have b18c t3/04e 57trim 60/63ar. 38mm tial wg .5bar spring vac from intake man., maxrev log manifold, 2.5 dp, 3in exhaust, drag icooler, 2in& 2.5 out piping. My car wont hold boost in upper rpms. I looked at my datalog from a 70mph roll on: from 3600rpm, peaked at 7.8 psi from 4300-4800rpm and gradually dropped to 1.3 psi at 6100rpm. I have checked all my piping and connectors& tightened the spring on my bov but no luck so far. anyone had this problem? I am running a screen with 3 layers of k&n filter material between another screen on the compressor inlet, could this be resticting it?
any help
Old Apr 25, 2006 | 04:46 PM
Jockobo's Avatar
Default Re: losing boost (jtracing919)
yes the screen is probably restricting it...try using one of the layers of filter material and see what it does...i went screen crazy once and went crazy trying to figure out why it wouldnt boost haha..
Old Apr 25, 2006 | 05:16 PM
I am planning on making a proper intake this weekend using piping and a k&n pod filter, but im just waiting on parts to show up. hopefully that will fix it
Old Apr 25, 2006 | 06:04 PM
Sketch_hs's Avatar
try running with out a filter just to test
have you tested your charge pipes? like pressurized the system?
Old Apr 25, 2006 | 07:27 PM
i will try it without a filter and see if that helps. I havent pressure tested the system, but I have a hard time believing that it is leaking when it holds 7 psi at lower rpms, higher rpms dont require more pressure but more volume of air do they not. I'm not sure though, and I'm grasping at straws here at the moment. I am also going to try and run my vac source to my wgate from a source closer to the compressor to see if maybe that helps
Old Apr 26, 2006 | 08:15 AM
bump
Old Apr 26, 2006 | 06:30 PM
i removed my ghetto filter made of screen and k&n filter material. The car pulls great and holds boost, actually its boosting to much now???
Old Apr 26, 2006 | 09:58 PM
Sketch_hs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jtracing919 &raquo;</TD></TR><TR><TD CLASS="quote"> i removed my ghetto filter made of screen and k&n filter material. The car pulls great and holds boost, actually its boosting to much now???</TD></TR></TABLE>
duhh
it's a huge restriction
now make a real intake setup or just slap the biggest k&n you can get on there. they have a HUGE selection of custom filters
Old Apr 27, 2006 | 06:57 AM
Default Re: losing boost (Sketch_hs)
its not that I wanted to run that set up, there is just very little room in there and my turbo inlet is directly in front of my clutch slave cylinder (inlet faces pass side) so just slapping a filter on it isnt such an easy task. I'm gonna try and make something outta piping and some silicone elbows 2day
Old Apr 27, 2006 | 07:23 AM
turboH22Aakkord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jtracing919 &raquo;</TD></TR><TR><TD CLASS="quote">its not that I wanted to run that set up, there is just very little room in there and my turbo inlet is directly in front of my clutch slave cylinder (inlet faces pass side) so just slapping a filter on it isnt such an easy task. I'm gonna try and make something outta piping and some silicone elbows 2day</TD></TR></TABLE>
im the same way man... (h22 in a CB7) and i have nooo room for a filter... but the K&N website does have a really good selection of custom filters!... good luck man.
carlos8
Jan 4, 2015 12:54 AM
ldanphanl
Jul 8, 2005 07:46 PM
Boosted2K
Oct 21, 2004 08:53 AM
Boosted2K
Oct 20, 2004 07:39 PM
ceemarun
Jul 15, 2002 08:40 PM
