does the turbo shake when you boost?
Old Jul 15, 2002 | 04:18 PM
ceemarun's Avatar
Default does the turbo shake when you boost?
ok, my filter doesnt clear the hood, so i gotta slam it in order to close the hood. i can deal with that, but i got my hondata tuned today so i can actually boost now, and when the turbo spools, it shakes. or at least it shakes enough for the piping to to move (piping to the filter). or am i just being dumb and the piping is shaking because it sucks in more air during boost?
anyhow, this is annoying. is there anything else i can do?
Old Jul 15, 2002 | 04:19 PM
TenaciousC's Avatar
Default Re: does the turbo shake when you boost? (ceemarun)
the whole motor flexes
Old Jul 15, 2002 | 04:32 PM
GruvyTune's Avatar
New User
should not shake.
Old Jul 15, 2002 | 04:39 PM
ceemarun's Avatar
Default Re: does the turbo shake when you boost? (GruvyTune)
figured out turbo isnt shaking, but im sure the intake piping vibrates or shakes when its sucking more air when boosting, right?
Old Jul 15, 2002 | 05:30 PM
ekb18c's Avatar
If turbine shakes you got problems.
edit- nothing should really be shaking!
[Modified by ekb18c, 2:30 AM 7/16/2002]
Old Jul 15, 2002 | 06:01 PM
ceemarun's Avatar
Default Re: does the turbo shake when you boost? (ekb18c)
alright, turbine and compressor isnt shaking, but i hear a fat vibrating rattle when i go into boost. after i hit 2lbs, and at WOT, something shakes, so im assuming its triggered by boosting.
when youre boosting, the air filter sucks in more air, causing it to shake right? cuz right now, my filter is touching the hood.
Old Jul 15, 2002 | 06:08 PM
supergreenNA1's Avatar
New User
make sure none of the piping is hitting the body of the car. as the rpms increase, your engine will vibrate more which causes the i/c piping to vibrate.
Old Jul 15, 2002 | 07:30 PM
Vsm Hatch's Avatar
Check your ac lines, too. (if you have ac) Like everyone is saying, the higher the rpm the more your whole engine shakes. So, my guess is that your turbo might be hitting your ac lines?
I doubt it is your filter. It shouldnt be shaking or someting is wrong. Good luck
Old Jul 15, 2002 | 08:40 PM
SIK IN DA HED's Avatar
New User
Default Re: does the turbo shake when you boost? (LiL_Kid)
dude get a smaller air filter already.
Turbo Dan
Aug 2, 2006 05:48 AM
hatchyboy89
Mar 2, 2006 04:01 PM
89crxsleeper
Nov 26, 2005 08:19 PM
chihuahuamanx
Feb 23, 2005 11:34 PM
jolt-tsp
Nov 20, 2004 09:13 PM
