A little Spray with a built turboed B16a a bad idea????
Wassup guys?
I finally managed to get my B16A2 built after boosting a little high with a bad tune I'm currently running the Max Rev kit with stock 6.5psi spring. I'm just completing building it with Eagle Rods, JE 9:0:1 Pistons, ARP Head Studs, ARP Rod Bolts, New Bearings and all that.
I also recently bought the S200B off Doug so I have the management sorted now!!
I just wanted to know what u guys think about spraying a little Nitrous into the equation??? I know the Hondata can manage it... Also what kinda boost level would be best to tune at? looking at the flow tables my T3/T04e flows best around 16/18psi!!! Would this be the best level to tune at???
Any Help would be most appreciated!!
TIA.
TIA.
Re: A little Spray with a built turboed B16a a bad idea???? (T-Blaze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-Blaze »</TD></TR><TR><TD CLASS="quote">Wassup guys?
TIA.</TD></TR></TABLE>
yeah nitrous will feel realy nice. i would tune the car first on boost then mess with the nitrous.
Re: (T-Blaze)
Greeedy fo da needy!! WHY?? ask yourself this. You'll make plenty of power and will be more than happy with ur T3/T4. As ur not running a particularly big turbo, u ain't got that much lag to need the use of giggle gas to spool u up. It theres more bad than good putting one in as you'll have to also retune for nawz (u are planning on retuning it aren't u?? ), unless hondata has this function built in and its intelligent enough to use different maps when running with/without nawz (I doubt it somehow...). Can Hondata experts confirm this??
RACEPAK
08-21-2005 09:09 AM
Benjithx
12-11-2004 01:31 PM
