The link in Faq on pre turbo engine builds Is not working
Can anyone find it again or summarize what are good things to do before turboing your engine to allow it to be more reliable/make more power. So far I was going to replace the rods,valves,valve springs, head studs, and I was going to put in a golden eagle block gaurd. Anything I don;t need anything else i should have?
0x5359-0055
Re: The link in Faq on pre turbo engine builds Is not working (Powerforcheap)
Get it sleeved, best thing you can do
Also, drop compression to as close to 8.5:1 as possible
Re: The link in Faq on pre turbo engine builds Is not working (Vt4cPwn35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt4cPwn35 »</TD></TR><TR><TD CLASS="quote">Get it sleeved, best thing you can do
Also, drop compression to as close to 8.5:1 as possible</TD></TR></TABLE>
listen to the first thing the guy said not the second
cheap way just throw some pistons and rods in the block and get headstuds.
you can run 10:1 compression if you want just find a good tuner
Are you looking for this link?
http://forums.evans-tuning.com...build
