rpm based boost controller.
Old Jun 29, 2003 | 01:12 AM
NyQuiL's Avatar
Default rpm based boost controller.
Can anyone explain these?
does anyone here have one, if so hows it workin for you?
What brands make these?
Old Jun 29, 2003 | 01:20 AM
Tywash's Avatar
I believe Apex-i makes one.
Old Jun 29, 2003 | 01:24 AM
paulzy's Avatar
Default Re: rpm based boost controller. (NyQuiL)
yeah, I believe the AVC-R has these features...go to the site. http://www.apexi-usa.com
I believe this is how the venom car is controlling boost right now
Old Jun 29, 2003 | 10:33 AM
Pengo's Avatar
Default Re: rpm based boost controller. (Paul_Vang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paul_Vang &raquo;</TD></TR><TR><TD CLASS="quote">yeah, I believe the AVC-R has these features</TD></TR></TABLE>
yup
Old Jun 29, 2003 | 11:30 AM
AlphaKennyWun's Avatar
Default Re: rpm based boost controller. (Pengo)
whats the theory behind this? i mean would you want more boost at higer rpm or lower boost? if the front tires are spinning and the rpm is shooting up, is higher boost what you really want?
Old Jul 3, 2003 | 05:58 PM
Default Re: rpm based boost controller. (S03Burner)
bizzump...anyone know?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S03Burner &raquo;</TD></TR><TR><TD CLASS="quote">whats the theory behind this? i mean would you want more boost at higer rpm or lower boost? if the front tires are spinning and the rpm is shooting up, is higher boost what you really want?</TD></TR></TABLE>
Old Jul 3, 2003 | 10:13 PM
NyQuiL's Avatar
no clue, but another one i heard is the greddy e-01
Old Jul 3, 2003 | 10:18 PM
Pritos's Avatar
New User
yep, the avc-r has it. As for it's use.... *shrug* I'm assuming it'll be helpful in a drag setup where you can limit boost in the lower rpm's to minimize spin.
That's what I would use it for.
Then I'd use the scramble boost to bump it up even more once I hit 3rd and 4th and traction isn't an issue.
Old Jul 3, 2003 | 10:59 PM
Daniel's Avatar
I'm guessing for traction purposes? Then you can incrementally increase the boost (horsepower/torque) as the RPMs rise, which might keep the wheels from spinning too early if, say, you reach 10/15 psi by 4500 rpm. I don't know. . . .
Old Jul 4, 2003 | 04:05 AM
simoh's Avatar
Default Re: rpm based boost controller. (Daniel)
It would be pretty cool if you could "shape" the wheel torque curve with boost and rpm. Being on the edge of traction through 1-2-3 gear would make for the fastest possible acceleration. And if you knew how much torque is required for breaking the tires loose you could shoot for a little under that.
xtremvw
Jun 4, 2008 09:11 AM
turboedc2
Jul 13, 2006 03:26 PM
integlspwr2k
Sep 8, 2005 03:20 PM
LSVtechnologytur...
May 2, 2005 05:18 PM
Kack
Aug 25, 2003 11:25 PM
