Launch controller (msd, chipped ecu, whatever)
Old Oct 31, 2005 | 01:06 PM
teefunk01's Avatar
Default Launch controller (msd, chipped ecu, whatever)
How many of you turbo guys are using a full launch controller at the dragstrip? what do you set your rpms at?
Old Oct 31, 2005 | 02:59 PM
raene's Avatar
Default Re: Launch controller (tphan4)
6000 rpm here. I don't launch at WOT because it melts the slicks off the line otherwise (I have some really old 22" slicks).
Old Oct 31, 2005 | 04:24 PM
adseguy's Avatar
5200rpm on Drag Radials at 11PSI tire pressure before heating them up.
You can run a lot of different combinations like higher revs and easing in the clutch or lower revs dropping the clutch in with low tire pressure etc etc. No one way to do it really. Seat time is the best way
Old Nov 1, 2005 | 08:31 AM
teefunk01's Avatar
Default Re: Launch controller (adseguy)
does launching off the two step benefit your car with boost at all? because arent you in full boost already at aroun 5k 6k rpm?
Old Nov 1, 2005 | 11:53 AM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tphan4 &raquo;</TD></TR><TR><TD CLASS="quote">does launching off the two step benefit your car with boost at all? because arent you in full boost already at aroun 5k 6k rpm?</TD></TR></TABLE>
No, I build maybe 1 PSI this is because there is no load on the engine it's only boncing off the limiter. To build boost off the line you need a SMALL turbo or use anti-lag which not many honda user due because it's pretty bad for the turbo/engine.
I use 2-step as a "consistent" launch. It keeps my mind on clutch and tire play and not have to worry about the gas pedal at all. On the street it's great because I consistenly get the same launch
Old Nov 1, 2005 | 06:40 PM
teefunk01's Avatar
has the two step helped your 60" times at all....what are you guys doing for launch just full throttle?
Old Nov 1, 2005 | 07:50 PM
vaporboy12's Avatar
with a msd 2 step i build like 10 psi on the line with a big turbo
Old Nov 1, 2005 | 09:58 PM
adseguy's Avatar
Default Re: Launch controller (vaporboy12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote">with a msd 2 step i build like 10 psi on the line with a big turbo</TD></TR></TABLE>
that's cause it cuts the ignition. Uberdata/Crome/Hondata cut fuel instead which won't build a lot of boost
Old Nov 2, 2005 | 07:25 AM
raene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tphan4 &raquo;</TD></TR><TR><TD CLASS="quote">has the two step helped your 60" times at all....what are you guys doing for launch just full throttle?</TD></TR></TABLE>
I have to part-throttle it or I roast the slicks in 1st (22" slicks). It's either the slicks or the clutch (ACT 6-puck), I'm not sure which yet
Old Nov 2, 2005 | 07:36 AM
pheurton-skeurto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">
that's cause it cuts the ignition. Uberdata/Crome/Hondata cut fuel instead which won't build a lot of boost </TD></TR></TABLE>
you have to watch with the 2-steps that cut ignition and not fuel, ive heard a few different horror stories about people throwing rods because of the ignition based 2-steps. hondata/ crome/etc seem to be the safer of the two types.
as for launch rpms, i have all season tires and i launch my turbo prelude at 4500. works pretty well.
Old Nov 2, 2005 | 07:55 AM
XES's Avatar
XES
Default Re: Launch controller (pheurton-skeurto)
Aren't people that use 2 steps (like MSD) also retarding their timing while the launch limiter is on? If so...so much.
Old Nov 2, 2005 | 08:02 AM
nonvtecD's Avatar
5000 RPM launch with Uber, street tires...
Old Nov 2, 2005 | 08:22 AM
dthrone's Avatar
I use chrome @ 7500rpm at the track!
Old Nov 2, 2005 | 08:27 AM
twkdCD595's Avatar
Default Re: (nonvtecD)
hondata 2 step... set @ 3k and I modulate the gas after I let out the clutch... still cannot hook worth a **** on these crappy street tires.
Old Nov 2, 2005 | 09:50 AM
b18ccivics's Avatar
Default Re: (twkdCD595)
6000 rpm at 6.5 psi of boost running gsr and aem ems on 22-8-15 slicks 1.800 60 foot.
Old Nov 2, 2005 | 01:48 PM
brokenboost's Avatar
Default Re: Launch controller (XES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pheurton-skeurto &raquo;</TD></TR><TR><TD CLASS="quote">
you have to watch with the 2-steps that cut ignition and not fuel, ive heard a few different horror stories about people throwing rods because of the ignition based 2-steps. hondata/ crome/etc seem to be the safer of the two types.</TD></TR></TABLE>
not sure but it seems to me that it would be better to cut spark rather than fuel on a boosted car
Old Nov 2, 2005 | 01:57 PM
vaporboy12's Avatar
Default Re: Launch controller (brokenboost)
yeah cutting fuel is a bad idea. cut the spark is ok.
Old Nov 2, 2005 | 02:29 PM
XES's Avatar
XES
Any thoughts on the timing retard on top of the spark cut?
Old Nov 2, 2005 | 06:12 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XES &raquo;</TD></TR><TR><TD CLASS="quote">Any thoughts on the timing retard on top of the spark cut?</TD></TR></TABLE>
That's called anti-lag and it's not good and THAT blows motors/turbos. Build boost hella well though and on a side note sounds mean
Old Nov 2, 2005 | 08:26 PM
vaporboy12's Avatar
it makes cool fire tooo
tegman23
Aug 1, 2008 09:28 AM
99delsol
Sep 16, 2006 05:40 PM
Jared
Apr 25, 2005 04:16 PM
turbo*s2k
Jul 9, 2004 02:14 PM
NyQuiL
Jul 4, 2003 04:05 AM
