Just a quick question
Old Aug 30, 2002 | 08:55 AM
BrokenVtec's Avatar
Default Just a quick question
Modified by 508@18psi at 2:30 AM 10/14/2003
Old Aug 30, 2002 | 09:02 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Just a quick question (Boooooooooost)
dont look at it as how much you can boost, but how is your fuel set up and how much can that support?
art
Old Aug 30, 2002 | 09:04 AM
falcongsr's Avatar
What is this crap?
Default Re: Just a quick question (Arturbo)
and your target horsepower/torque levels, or target 1/4 mile times (for you drag racers), or how much power your drivetrain / suspension will handle, or how reliable you want it to be. lots of variables, lots of perspectives.
Old Aug 30, 2002 | 09:23 AM
DIRep972's Avatar
Smarter than you
most the time, the turbo will support way more boost and a built block will handle way more hp then u will ever make. the way to determine how much boost to run is figure out how much power its going to make and whether or not u have enough fuel to support that.
my turbo spools to 8psi at 3800rpm, non ball bearing from revhard kit. id imagine urs would be 500rpms quicker or so.
Old Aug 30, 2002 | 09:28 AM
SiRkid's Avatar
Default Re: Just a quick question (DIRep972)
also most likely 15 psi(maybe18 or so) will be as high as you can go on pump gas
Old Aug 30, 2002 | 09:36 AM
DIRep972's Avatar
Smarter than you
NICE! what compression pistons u running? generally on 9:1 pistons 15psi is the limit on 93 octane, so on 100 octane, id go for 20psi.
Old Aug 30, 2002 | 11:41 AM
justagsr's Avatar
if you're not getting your head done you might to want to look into that with such high boosts....portflow titanium retainers and type r valve train. jmo (just my opinion)
Good luck and booooost away.
Orangeciv
Jul 31, 2008 05:08 PM
FullBoostAhead
Feb 10, 2004 01:51 PM
servion
Jun 30, 2003 10:25 AM
virginia_dude
Nov 5, 2002 09:49 AM
slowcivic
Dec 14, 2001 10:12 AM
