Just got a Drag kit for my GSR Need help?
Re: Just got a Drag kit for my GSR Need help? (JDMDC2909)
you need a hose to connect from the turbo to that fitting on the wastegate and to change the boost you either need a boost controller or change the spring in the wastegate otherwise it's preset through the wastegate spring
Yeah man, you need a boost controller in order to control boost. Nothing in the regular drag kit will allow you to do so.
As for your boost guage, tap it off of the fpr.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDC2909 »</TD></TR><TR><TD CLASS="quote">How do I adjust the BOOST on that thing..?..</TD></TR></TABLE>
uhh ohh .. I would suggest not turning the boost any higher on a Drag kit running an FMU.
Re: Just got a Drag kit for my GSR Need help? (dasher)
Thanks for the GOOD advice peeps.. .. Where on the FPR do I tap it for the BOOST gauge..And on the wastegate aint there a NUT that you can set the BOOST?
Is 7lb good for daily driven all stock gsr motor or should I just turn the boost down a little and how would I turn it down ? .. What do I need to make my motor run good for daily drive I dont want nothing too dramastic just the basic?
7lbs is fine .... later on I would upgrade to a standalone and bigger injectors for more power and reliability to boot.
NICE..Yea later on I was planning to put some ARP head studs,all the fuel set up,msd,vafc and a head gasket..would that solve everything for daily drive?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDC2909 »</TD></TR><TR><TD CLASS="quote">NICE..Yea later on I was planning to put some ARP head studs,all the fuel set up,msd,vafc and a head gasket..would that solve everything for daily drive?</TD></TR></TABLE>
take the money wasted on the un-needed VAFC, MSD, fuel rail, FPR and purchase Hondata or Neptune with some larger injectors and a couple hours on the Dyno.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dasher »</TD></TR><TR><TD CLASS="quote">take the money wasted on the un-needed VAFC, MSD, fuel rail, FPR and purchase Hondata or Neptune with some larger injectors and a couple hours on the Dyno.
