Is this JRSC setup complete?
Old Dec 2, 2002 | 07:44 PM
ModAddict's Avatar
Default Is this JRSC setup complete?
Am I missing anything? Going on a 99Si w/38k miles on it.
JRSC kit, used CRV crank pulley (10psi), new fuel filter, Walbro 255 fuel pump, RC 440cc saturated w/clips, existing AEM CAI converted to short ram, Hondata manifold gasket w/ longer studs, Kamikazi ceramic 2.5" collector, 2.5" test pipe, Tanabe race medalian w/ cat end modified 2.5" thru to the 60mm section, Hondata s100 w/boost, OBDII to OBDI harness, used OBDI ECU, NKG7 plugs, ACT HDSS clutch kit, Quaife LSD, Defi boost and fuel preasure gauges, Dyno tune.
Old Dec 2, 2002 | 09:51 PM
FMXer's Avatar
Default Re: Is this JRSC setup complete? (ModAddict)
Ya, Alot of $$
Old Dec 2, 2002 | 10:20 PM
sharkcohen's Avatar
Good list of parts. You might also want to consider a colder thermostat, colder fan switch, and higher pressure radiator cap.
Old Dec 2, 2002 | 11:22 PM
RyanAutry's Avatar
My old setup.
220+ WHP is in your future.
RyanAutry's Avatar
Default Re: Is this JRSC setup complete? (sharkcohen)
Not with the Hondata. Make sure you keep you engine running in operating temprature at all times.
Old Dec 3, 2002 | 04:39 AM
CRVRX's Avatar
Default Re: Is this JRSC setup complete? (RyanAutry)
Cam gears and a type R exhaust cam shaft, Then tunning !
Old Dec 3, 2002 | 05:26 AM
sharkcohen's Avatar
Why not?
Old Dec 3, 2002 | 02:19 PM
ModAddict's Avatar
Default Re: Is this JRSC setup complete? (FMXer)
Ya, Alot of $$
Merry Christmas
Old Dec 3, 2002 | 02:24 PM
ModAddict's Avatar
Default Re: Is this JRSC setup complete? (CRVRX)
Damm! I knew I missed something. mmmmm........
Thanks!
Old Dec 4, 2002 | 12:03 PM
RyanAutry's Avatar
Why not?
Email Doug at Hondata. Ask him why it is essential to keep your car running in operating temp at all times when using Hondata.
He can explain it better then I.
forryk
Jan 15, 2011 07:52 PM
oacrep1
Feb 6, 2006 07:34 AM
- Sim -
Dec 16, 2004 09:07 AM
Ski2001
Dec 10, 2002 04:36 AM
