jrsc ? please help
Old Feb 24, 2004 | 10:04 PM
00bluesi's Avatar
Default jrsc ? please help
I'm planning on upgrading my jrsc kit with a 9lb pulley. and tuning it with hondata and 440's, is that ok on a stock block that has 70000 miles on it
Old Feb 24, 2004 | 10:54 PM
Robzible's Avatar
Default Re: jrsc ? please help (00bluesi)
o hyeah man should be fine , just make sure you get it plenty of fuel and timing!! because from what i know those jrsc's push out some pretty hot air , anyway though i think it will be ok as long as you have the timing and fuel to it , i would also suggest you get an msd btm
Old Feb 25, 2004 | 12:08 AM
greekspeed's Avatar
Default Re: jrsc ? please help (Robzible)
i know of 2 civic si's running 12 psi with the jrsc on stock motors.....
hondata, 440's, and add a in-take fuel pump u will be more than safe... as long as u tune it decent.
Old Feb 25, 2004 | 10:03 AM
00bluesi's Avatar
Default Re: jrsc ? please help (greekspeed)
should i also consider upgrading my fuel rail with the 440's i'm getting
Old Feb 25, 2004 | 11:38 AM
00bluesi's Avatar
bump this
Old Feb 25, 2004 | 11:40 AM
Silverbeast's Avatar
Stock fuel rail will be fine. I reccomend getting a true 1:1 fuel pressure regulator. Anyone tuning your Hondata will tell you the same thing. Other than that those injectors will be perfectly fine for this application.
Old Feb 25, 2004 | 11:55 AM
MADEINIRAQ's Avatar
Default Re: (Silverbeast)
what pulley setup are you looking to use?
i'm using motorvations motorsport stepper pulley. (205) 661-3600
give them a call
uncledan
Aug 18, 2008 09:39 AM
larryd
Oct 12, 2004 03:18 PM
slammed00si
Mar 8, 2004 06:38 PM
2K Teggy
Mar 4, 2004 06:14 PM
Scharged2000GsR
Oct 26, 2003 04:40 PM
